Go to Post It's not a rendering mistake, it's a design challenge! - Eric Scheuing [more]
Unread 01-10-2013, 22:04
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
4488 Off-season Gearbox
So last year our drive train had some issues with a center chain in a WCD, so we decided this was finally going to be the year we actually made a direct drive gearbox in order to fix these problems. This is what we came up with. Its a direct drive single speed gearbox with toughbox spacing except for 12 tooth pinions instead of 14 tooth pinions. The only question I have is if the material surrounding the bearings is enough. Right now they are between .2 and .3 inches. Should I make them thicker, or is that good enough? Also do you think there is anything I can do to make it better.
Ok got the correct pictures.
ID:	15245  Click image for larger version
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 01-10-2013, 23:27
T^2 T^2 is offline
FRC #5499
Rookie Year: 2011
T^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond repute
Re: 4488 Off-season Gearbox
1. It's probably thick enough. I think the standard is .25".
2. This looks pretty similar to WestCoast Products' shifting gearbox. So similar, in fact, that I question the need for you guys to fabricate your own. I doubt you can do much better than their price of $250 per gearbox, and you'll save a lot of time. Of course, if the goal is to get experience in design and machining, by all means go ahead.
Unread 01-10-2013, 23:39
Rookie Year: 2010
I looked at the WCP gearboxes, but we dont have the money for the dual-speeds, and I really dislike the ratios on the Single speed. The ratios this can get are much better for our needs
Unread 02-10-2013, 02:17
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
I'll echo what T^2 had to say, and suggest you take a serious look at the WCP SSes. I'm not sure when you last checked, but they've updated their product line since the season. You can get a reasonable ratio on basically any FRC diameter wheel out there, and I'm fairly sure that you can get a similar gearing to what you're getting with the Toughbox. They're really awesome products for the money, and we've been very satisfied with out DSes.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 02-10-2013, 02:27
Rookie Year: 2010
For 6 inch wheels they jump from 7.9FPS to 16.5FPS. There is no in between with the WCP ones. That is tough, because in most games 7.9 is too slow, and 16.5 is too fast for a single speed. Plus at $150 a piece, we have bought all the gears, shafts and materials for about $100, which is much cheaper. If they could get a 10FPS option with 6 inch wheels, that would make them look better, but they would still be too expensive.
Unread 02-10-2013, 03:10
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
Rookie Year: 2011
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
It looks good, nice work. If you're not content with existing gearboxes then you got yourself a good solution.
As for the thickness, it should do, but you should always run simulations to make sure.
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
Unread 02-10-2013, 10:07
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
You're forgetting to factor in time. By buying the gearboxes you save time, and that can be worth $50 extra per gearbox.
Unread 02-10-2013, 10:22
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Originally Posted by AdamHeard View Post
You're forgetting to factor in time. By buying the gearboxes you save time, and that cab be worth $50 extra per gearbox.
$50/gearbox is well worth the cost if it saves us from designing, fixturing, machining and troubleshooting the gearbox plates, spacers and shafts.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 02-10-2013, 12:11
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Also keep in mind that 6" wheels are a bit big. For ground clearance they are ok but in most games you can go with smaller wheels.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 02-10-2013, 12:22
Rookie Year: 2010
I know 6 inches are big, and we plan on using 4s, but I like contigencies. Also, can you fit an AM Kit wheel or a VexPro VersaWheel onto the 1.25 inch output shaft? Everytime I look those wheels are wider, and I don't even know how you would mount those to a 1.25 inch long output shaft.
Also its about ~$100 extra per gearbox, not $50.
Unread 02-10-2013, 12:35
AdamHeard's Avatar
Lead Mentor
WCP sells theirs single speed for $150, are you saying you can make the above single speed for $50? I'd love to get your suppliers
Not trying to pick on you, it's just I'm not buying the cost argument.
Making your own box for people to learn, so it's yours, so it's cool, etc... are all valid reasons, but I don't see this saving appreciable amounts of money (and it saves that money at appreciable amounts of time).
EDIT: On some more thought, $50 per gearbox isn't implausible. It's a little lower than what we spent, but not impossible.
Unread 02-10-2013, 12:36
Andrew Lawrence
Posts: n/a
Someone somewhere may have told me prices will be going down sometime.
Just don't knock out WCP's gearbox. I'm holding some in my hand right now and it's a beautiful thing with perfect ratios. Like you mentioned it is for a WCD which is designed for 4" wheels. If you're making a WCD you should have no need for anything larger than 4" wheels.
Unread 02-10-2013, 12:43
I know 6 inches are big, and we plan on using 4s, but I like contigencies..
Contingencies are always a good thing, but remember 'jack of all trades, master of none'. You often are making sacrifices to be able to account for large varieties of wheels, etc. While this time of year is absolutely the best time of year to explore those options, when its time to start spending money and cutting metal on a build-season robot, the best bang for your buck may be a very focused design.
-Brando
Unread 02-10-2013, 12:57
Rookie Year: 2010
Total cost not including the metal for the plates, is $101.8 all from Vex. Thats enough for 2 gearboxes. The only thing that doesnt include is the sprockets, which the WCP doesnt include either so its moot.
As for machining, at our school we have 9 lathes, 3 mills, a CNC, and students who know how to use all of them. During week 1, we have kids that are much more interested in machining then designing, so we can make these during down time, when we don't have a full robot designed yet.
I'm not writing them out, and if we run into trouble that will be option 1. But I think we could do it more efficiently, cheaper and more focused to our needs by doing it manually. Plus it will keep the students occupied week 1.
Also what 4 inch wheels actually fit the 1.25 inch output shaft? I'd love to know, so we could make ours even shorter if needed.
  #15   Spotlight this post!
Unread 02-10-2013, 18:56
Rookie Year: 2010
The gearbox is designed to fit their colson hubs. Colsons come in a lot of sizes. Here is a 5" one that as far as I know will fit their hubs: http://www.robotmarketplace.com/products/BPDWC14.html
Also if you want to use wider wheels what we did was tap the end of the shaft and put a spacer(we put hex, can be round) to get the extra length needed.
Keep in mind that the WCP product is an end all solution. It just works. If you design your own you will need to prototype(you will not get it right otherwise). Also you will have to make your own replacements if parts fail(WCP takes care of you on this). Lastly the time can just be better used elsewhere. Sure people may not like designing, but prototyping is very important. If you don't want to buy premade bearing blocks(WCP sells COTS ones too) than those need to be amchined for a WCD. Drive rails and shafts are more things that can be machined week 1.
