Go to Post If mentors don't respect the students' desire to learn and take an active role in the construction, they're missing the point of FIRST. If students refuse to accept the knowledge and experience of the mentors, that's not independence - it's arrogance. - DB213parent [more]
Unread 02-10-2013, 14:30
IKE's Avatar
IKE IKE is online now
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Durability in FRC
As many new areas are going into District format, I would like to remind folks about designing for durability.
In the past, if you went to one regional, you could expect 8 qualifying matches and hopefully at least 4 Elims matches (making it to semis). Basically, you could plan on 12-20 matches.
Now, playing districts, you might see 12 qualifying, and have an even higher likelihood of making it into elims. Plus you will be doing at least 2 events which means a high likelihood of 30-40 matches. Plus another 12-20 if you make it to a district championship. plus another 20-ish if you play a third district. Plus another 12-20 if you make it to championship...
Last year FRC33 had 92 official matches at teh end of the World Championship. Throw in a few practice matches at each event, and they likely exceded 100 matches.
Then with offseasons, teams may see another 20-30 matches. Suddenly you have a need for a robot to last 150 matches instead of 15-ish...
Total run time changed from under 1 hour to around 7 hours.
What (if anything) are teams doing now that they are seeing a lot more matches?
