Go to Post 1902...hmmmmm did it go oink oink boom when it blew up? - Rohith Surampudi [more]
Unread 02-10-2013, 14:30
IKE's Avatar
IKE IKE is online now
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Durability in FRC
As many new areas are going into District format, I would like to remind folks about designing for durability.
In the past, if you went to one regional, you could expect 8 qualifying matches and hopefully at least 4 Elims matches (making it to semis). Basically, you could plan on 12-20 matches.
Now, playing districts, you might see 12 qualifying, and have an even higher likelihood of making it into elims. Plus you will be doing at least 2 events which means a high likelihood of 30-40 matches. Plus another 12-20 if you make it to a district championship. plus another 20-ish if you play a third district. Plus another 12-20 if you make it to championship...
Last year FRC33 had 92 official matches at teh end of the World Championship. Throw in a few practice matches at each event, and they likely exceded 100 matches.
Then with offseasons, teams may see another 20-30 matches. Suddenly you have a need for a robot to last 150 matches instead of 15-ish...
Total run time changed from under 1 hour to around 7 hours.
What (if anything) are teams doing now that they are seeing a lot more matches?
