Go to Post ...because "someone on ChiefDelphi said so," doesn't fly when your robot can't pass inspection. - Madison [more]
Unread 02-10-2013, 16:42
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
Rookie Year: 2011
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
LabVIEW, have throttle run motor?
Have been trying to have my kop joystick throttle (axis 3) to vary the “set output” for my shooter motor if button 2 is pressed and boutton 3 is not pressed. As for boutton three when it is pressed the shooter should be and so far has been, running at %90 (.9 in LV). what am I doing wrong in these case structures?
*In the one photo B=bouton.
ID:	15247  Click image for larger version
ID:	15249  Click image for larger version
Name:	B2 off B3 on.JPG
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 02-10-2013, 17:07
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: LabVIEW, have throttle run motor?
Would something like this do what you want?
Unread 02-10-2013, 17:26
jman4747's Avatar
AKA: Josh
Team Role: CAD
Rookie Year: 2011
Thanks that looks good. I,ll try it and see. The only other thing I was worried about with this section of the code was if the axis 3's output numbers were 0-1 or not and if I needed to put an algorithm in between the axis 3 output and the set motor input so set motor did the right thing with it.
#banthebag
#RIBMEATS
#1620
Unread 02-10-2013, 17:32
Ether's Avatar
Rookie Year: 1969
Originally Posted by jman4747 View Post
The only other thing I was worried about with this section of the code was ... if I needed to put an algorithm in between the axis 3 output and the set motor
If so, break the wire at the red arrow and insert your code there.
