Go to Post Turning is overrated - Allison [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 06-10-2013, 21:37
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: calculating position using follower wheels
Just for fun.
ID:	15276  Click image for larger version
ID:	15277  Click image for larger version
ID:	15278  Click image for larger version
ID:	15279  Click image for larger version
Name:	path distance vs time.png
Unread 06-10-2013, 02:20
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Originally Posted by Ether View Post
Ryan: what CAS did you use for that? The syntax you used was rejected by Maxima, Octave, and SciLab.
It's Mathematica's syntax, which is also accepted by Wolfram Alpha, making it useful for quick one-line integral problems.
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 07-10-2013, 18:32
Ether's Avatar
Rookie Year: 1969
A certain robot with a 3 degree-of-freedom drivetrain (FWD, STR, RCW) is on a flat level floor. At time T=0, its center of geometry (CoG) is located at the origin of an XY coordinate system fixed with respect to the floor; it is facing 15 degrees clockwise from the +Y axis; and it has the the following robot-centric constant motions:
forward = 5 ft/s
strafe_right = 4 ft/sec
rotate_CW = 120 degrees/sec
Question 1: What are the coordinates 3 seconds later, and what direction is the robot facing?
Question 5: Same as Question 1 (above), except:
forward = 5*sin(t/2) ft/s
strafe_right = 4*sin(t/2.2) ft/sec
rotate_CW = 1.5*sin(t/2.5) radians/sec
5a) What are the XY coordinates 30 seconds later?
5b) What is the path length traveled during that 30 seconds?
Unread 07-10-2013, 19:01
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Spoiler for solution:
X position: -5.9443 ft
Y position: -9.1103 ft
Distance: 129.5972 ft
MATLAB:
Spoiler for code:
Code:
rotate_CW = @(t) 1.5*sin(t/2.5);
angle = @(t) 5*pi/12 - integral(rotate_CW, 0, t, 'ArrayValued', true);
forward = @(t) 5*sin(t/2);
strafe_right = @(t) 4*sin(t/2.2);
xvel = @(t) cos(angle(t)) * forward(t) + cos(angle(t) - pi/2) * strafe_right(t);
yvel = @(t) sin(angle(t)) * forward(t) + sin(angle(t) - pi/2) * strafe_right(t);
xpos = @(t) integral(xvel, 0, t, 'ArrayValued', true);
ypos = @(t) integral(yvel, 0, t, 'ArrayValued', true);
spd  = @(t) sqrt(forward(t)^2 + strafe_right(t)^2);
distance = @(t) integral(spd, 0, t, 'ArrayValued', true);
x_position = xpos(30)
y_position = ypos(30)
distance = distance(30)
Last edited by flameout : 07-10-2013 at 19:04. Reason: Units and nicer MATLAB output
Unread 07-10-2013, 19:22
Ether's Avatar
Rookie Year: 1969
MATLAB:
Spoiler for code:
Code:
Impressive. Reps to you.
Unread 07-10-2013, 19:36
RyanCahoon's Avatar
Rookie Year: 2007
Spoiler for 5a:
T=0: (0,0) pi/12 (from +Y axis)
F(t) = 5*sin(t/2)
S(t) = 4*sin(t/2.2)
dQ = 1.5*sin(t/2.5)
Q(t) = (Integrate[1.5*Sin[t/2.5], t, 0, t]) + Pi/12 = 4.0118-3.75*Cos[0.4*t]
T=30:
dX(t) = F(t)*Sin[Q(t)]+S(t)*Cos[Q(t)]
X = Integrate[dX(t), t, 0, 30]
= Integrate[5*Sin[t/2]*Sin[4.0118-3.75*Cos[0.4*t]] + 4*Sin[t/2.2]*Cos[4.0118-3.75*Cos[0.4*t]], t, 0, 30]
= -5.94429
dY(t) = F(t)*Cos[Q(t)]-S(t)*Sin[Q(t)]
y = Integrate[dY(t), t, 0, 30]
= Integrate[5*Sin[t/2]*Cos[4.0118-3.75*Cos[0.4*t]] - 4*Sin[t/2.2]*Sin[4.0118-3.75*Cos[0.4*t]], t, 0, 30]
= -9.11027
Spoiler for 5b:
FWD = 5*sin(t/2) ft/s
STR = 4*sin(t/2.2) ft/sec
RCW = 1.5*sin(t/2.5) radians/sec
T=30:
distance = Integrate[Sqrt[(dX(t))^2+(dY(t))^2], t, 0, 30]
= Integrate[Sqrt[(5*Sin[t/2]*Sin[4.0118-3.75*Cos[0.4*t]] + 4*Sin[t/2.2]*Cos[4.0118-3.75*Cos[0.4*t]])^2+(5*Sin[t/2]*Cos[4.0118-3.75*Cos[0.4*t]] - 4*Sin[t/2.2]*Sin[4.0118-3.75*Cos[0.4*t]])^2], t, 0, 30]
= 129.597
Unread 07-10-2013, 19:48
Ether's Avatar
Rookie Year: 1969
Originally Posted by RyanCahoon View Post
Spoiler for 5a:
F(t) = 5*sin(t/2)
S(t) = 4*sin(t/2.2)
dQ = 1.5*sin(t/2.5)
T=30:
= -5.94429
= -9.11027
Spoiler for 5b:
T=30:
= 129.597
Nice work too. You guys rock.
Unread 07-10-2013, 19:51
Ether's Avatar
Rookie Year: 1969
In one hour from the time of this post, I will post Question 6.
Unread 07-10-2013, 19:55
AKA Ryan Van Why
FRC #0957 (SWARM)
I've refactored my code to be much faster (using basic manual Euler integration instead of MATLAB's integral() function) and plotted the robot's position for problem 5. The plot is attached.
Here is the code. I would have done this in C++, but MATLAB lets me plot much more easily
Spoiler for code:
Code:
% Set up various useful functions that don't require integration to calculate
xvel = @(t,angle) cos(angle) * forward(t) + cos(angle - pi/2) * strafe_right(t);
yvel = @(t,angle) sin(angle) * forward(t) + sin(angle - pi/2) * strafe_right(t);
% Set parameters and initialize variables (preallocating variables for performance)
duration = 30;
steps    = 30000; %dt = 1 millisecond
dt       = duration / steps;
angle    = zeros(1,steps+1); % Off by one -- t = 0 is also in each vector
xpos     = zeros(1,steps+1);
ypos     = zeros(1,steps+1);
distance = zeros(1,steps+1);
% Initialize angle to 15 degrees positive off the Y axis
angle(1) = 5*pi/12;
% Do the integration. Using Euler integration
for iter = 1:steps
	time             = duration * iter / steps;
	xpos(iter+1)     = xpos(iter) + dt * xvel(time, angle(iter));
	ypos(iter+1)     = ypos(iter) + dt * yvel(time, angle(iter));
	distance(iter+1) = distance(iter) + dt * spd(time);
	% No intuitive tricks with angle here -- just do stupid simple Euler integration.
	angle(iter+1)    = angle(iter) - dt * rotate_CW(time);
end
Last edited by flameout : 07-10-2013 at 20:04. Reason: Inserting forgotten code tags
Unread 07-10-2013, 20:26
Ether's Avatar
Rookie Year: 1969
I've refactored my code to be much faster...
How slow was it before? Maxima solves Question 5 in less than half a second:
Code:
Maxima 5.27.0 http://maxima.sourceforge.net
using Lisp GNU Common Lisp (GCL) GCL 2.6.8
assume(t>0)$
Qo: 15/180*%pi$
dFdT: 5.0*sin(t/2.0)$
dSdT: 4.0*sin(t/2.2)$
dQdT: 1.5*sin(t/2.5)$
Q: Qo + integrate(dQdT,t,0,t)$
dXdT: dFdT*sin(Q)+dSdT*cos(Q)$
dYdT: dFdT*cos(Q)-dSdT*sin(Q)$
dLdT: sqrt(dXdT^2+dYdT^2)$
quad_qags(dXdT, t, 0, 30);
       [- 5.94428316349145, 5.1523954241625701E-10, 315, 0]
quad_qags(dYdT, t, 0, 30);
       [- 9.110270199929753, 3.4870273187953572E-10, 315, 0]
quad_qags(dLdT, t, 0, 30);
       [129.5971872631463, 1.1496649242892635E-6, 441, 0]
...using basic manual Euler integration
Use trapezoidal instead. It's very simple to do and much more accurate, so you can use fewer steps and speed it up even more.
Also see Post 13 for a simple change to improve accuracy so you can use fewer steps and run even faster. Post 15 explains why.
Get yourself a copy of gnuplot. It's free and script-driven, so you can write a script to edit/compile/run/and plot your C++ program.
Unread 07-10-2013, 20:39
AKA Ryan Van Why
FRC #0957 (SWARM)
It took one or two seconds (MATLAB isn't terribly fast). It was entirely numerical, performing a numerical integration (for angle) inside another numerical integration (to get position).
Where it was painfully slow was plotting the position trajectory, where it needed to run the numerical integration inside a numerical integration over and over (plenty of redundant calculations). To get a high-quality plot would have taken over an hour of execution time.
If I really cared about accuracy and speed, I would be using Simpson's Rule integration (perhaps using trapezoidal first to get an error estimate, for adaptive integration). Also, I'd analytically solve for the integrals that are analytically solvable (such as the angle).
Another good technique would be to use an ODE solver rather than pure integration -- if I were to do this, I'd probably use MATLAB's built in 4th/5th order adaptive Runge-Kutta solver (ode45). This would probably be plenty fast as well.
I saw that, and considered doing that. I don't have a good reason for choosing what I did, other than that it "works" and is easy to explain (as a left-hand Riemann sum).
I really need to learn that sometime...
Unread 07-10-2013, 20:55
Ether's Avatar
Rookie Year: 1969
If I really cared about accuracy and speed, I would be using Simpson's Rule integration...
It's a cost/benefit thing. The cost of converting Euler to trapezoidal for this problem is very small. Going from trap to Simpson's would require more rework, make the code less readable, and probably even slow it down for equivalent accuracy.
It would be interesting to do a comparison. My guess is that for this problem, trapezoidal in compiled C would be just as fast for equivalent accuracy as RK in MatLab.
Unread 07-10-2013, 21:07
AKA Ryan Van Why
FRC #0957 (SWARM)
True (except for the last part -- I don't think Simpson's integration would slow it down for equivalent accuracy, but I haven't tried it, so I don't know).
Having used MATLAB a bit, I think compiled C++ w/ trapezoidal integration would be way faster for the same accuracy than MATLAB code using an RK-based solver.
Here's code that solves it using one of MATLAB's adaptive ODE solvers (4/5th-order Runge-Kutta (I don't recall which formulation it is)):
Spoiler for more code:
Code:
angle = @(t) 5*pi/12 - 3.75 + 3.75 * cos(t/2.5); % Obtained analytically (by hand)
% Set up for the ODE solution
tspan = [0 30];
x0    = [0; 0; 0]; % xpos, ypos, distance
% The ODE function
dynamics = @(t,x) [xvel(t); yvel(t); spd(t)];
% Call ode45
diffsoln = ode45(dynamics, tspan, x0);
% Function for obtaining the state at a given time (for plotting)
statefun = @(t) deval(diffsoln, t);
% Time values for plot (using a lot of points so it looks good).
times = linspace(tspan(1), tspan(2), 10000);
% X and Y positions
xpos = [1 0 0] * statefun(times);
ypos = [0 1 0] * statefun(times);
% Do the plotting
plot(xpos, ypos, 'LineWidth', 5)
Unread 07-10-2013, 21:13
Ether's Avatar
Rookie Year: 1969
Question 6:
Same as Question 5, except:
15 seconds instead of 30
and
rotate_CW = (e^T-1)^(1/17) radians/sec
  #15   Spotlight this post!
Unread 07-10-2013, 21:22
AKA Ryan Van Why
FRC #0957 (SWARM)
Question 6 solution:
Position: ( -3.7271, -4.0749)
Distance: 60.8613
Code (slightly modified from my last script):
Spoiler for code:
Code:
rotate_CW = @(t) (exp(t) - 1)^(1/17);
tspan = [0 15];
x0    = [0; 0; 0; 5*pi/12]; % xpos, ypos, distance, angle
% The ODE function
dynamics = @(t,x) [xvel(t, x(4)); yvel(t, x(4)); spd(t); -rotate_CW(t)];
% Call ode45
% X and Y positions
xpos = [1 0 0 0] * statefun(times);
ypos = [0 1 0 0] * statefun(times);
% Do the plotting
% Ending positions and distance
end_x    = xpos(end)
end_y    = ypos(end)
distance = [0 0 1 0] * statefun(tspan(2))
Perhaps I should stop and give someone else a chance to answer first -- this is way too easy when all I need to do is change a script I already wrote.
