Go to Post Besides, you know hard it is to solder with gloves on? - Al Skierkiewicz [more]
Unread 07-10-2013, 17:22
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Rookie Year: 2011
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
Custom camera server.
I am hoping to have a coprocessor that uses a webcam for the vision processing. The vision processing I have done. What I need to do now is stream the image to more custom software for the drivers to see. I have figured out basic use of sockets, and I found third party software to handle the server side streaming. How do I get the stream on the client side, knowing the exact port I am going to be using and assuming that the stream is an mjpeg. Does anyone have experience with network code and mjpegs? I could use some general pointers even if you can't explain everything.
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
