Go to Post some people sing in the shower........i pretend to be an emcee at championships......:cool: - BanksKid [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 23-06-2002, 22:48
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Can we really get 225 in-lbs from the drills?
Posted by Jason Rukes at 1/12/2001 1:53 PM EST
Engineer on team #109, Arial Systems & Libertyville HS, from Libertyville High School and Arial Systems Corp & SEC Design.
One of Woody's slides during the Kick-Off showed that a current-limited motor will have the same max speed, but less torque than a "current-unlimited" motor. That got me thinking about the drill motors and the effect of the 30A circuit breaker.
The datasheet states the drill motor will stall at 225 in-lbs(low speed). The torque constant is 5.836mN-m/Amp which means the motor can only generate 62in-lbs of torque at 30 amps before tripping the breaker.
Does this sound correct?
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
drills and chips Ben.V.293 Technical Discussion 1 07-11-2003 13:11
2003 Drills and Chips Chris Motors 3 12-10-2003 19:02
Image Discuss: Team 225 CD47-Bot Robot Showcase 3 10-02-2003 23:04
drills and gear housing... archiver 2001 4 23-06-2002 23:46
Bosch drills Joe Turner Motors 3 11-02-2002 13:56
