Go to Post "Its not a glitch its a new feature, we just dont know how to use it yet" - Cuog [more]
Unread 10-10-2013, 17:23
domingocool domingocool is offline
Programmer
FRC #4645 (X-Machina)
Rookie Year: 2012
domingocool is an unknown quantity at this point
Question [HELP] cRIO not imaging as it should be
So, we've been having trouble imaging our cRIO for two days and can't seem to figure out why. We periodically get the two blinks on the status lights so we installed NI MAX 5.5 and re-formatted the cRIO and re installed the software with all the add-ons. We set out LAN IP to 10.46.45.5 and the subnet mask to 255.255.255.0. When we try to image it it still doesn't image(or at least starts but puts an error(Error 7)). Also the modules never show up on the Imaging Tool nor are the little switches usable. We've tried everything we feel that we can so any help would be awesome. Thanks.
Unread 10-10-2013, 17:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: [HELP] cRIO not imaging as it should be
Have you pulled the modules and checked the condition of the pins in the chassis? The HD15 connectors are susceptible to bent pins if the modules are not installed correctly.
Unread 10-10-2013, 18:26
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
I would start with the basics. Can you go to a command prompt and ping the crio? Let's make sure you have communication first.
Also, you are connecting your ethernet cable directly to the crio from the computer, right?
Unread 10-10-2013, 18:32
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Rookie Year: 2012
Team3266Spencer is an unknown quantity at this point
Is it a 4 slot cRio?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 10-10-2013, 21:14
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
So far as I can tell, there's never a good reason to use NI MAX on a cRIO-FRC.
You say you installed "all the add-ons"? Does that include the FRC Utilities update? Error 7 usually means that a program can't find a necessary file. Perhaps you tried to run the update from inside the compressed folder without extracting the files first.
Unread 10-10-2013, 23:41
Programmer
Rookie Year: 2012
Yes it is
Programmer
Rookie Year: 2012
How do you go about pinging the cRIO with CMD?
Unread 11-10-2013, 00:19
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Pinging an IP (or website)
from the desktop with all windows minimized and an Ethernet link directly from your computer to the cRIO (powered on)
-hold /windows key (meta)/ and while holding, press /r/
-type "cmd" (no quotes)
-press /enter/
-type "ping" then /spacebar/ then "your cRIO's IP" (you said before: 10.46.45.5)
-press /enter/
It should look something like picture 1 ("google.com" will be "10.46.45.5"). Of course, the ping values may be different, but that is not what you are pinging to test, you just want any reply at all. If it looks like picture 2, I would try pinging "10.46.45.1" If that fails, you may have a problem. If it works and you DO get a reply, however, there may be hope yet...
Anyways, If it is bricked, NI probably has some sort of warranty on that...
ID:	15299  Click image for larger version
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 11-10-2013, 00:29
Happy Birthday! Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Rookie Year: 2012
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
If they used the FRC cRIO Imaging tool, shouldn't the cRIO IP be 10.46.45.2? I think 10.46.45.5 is the IP of their driver station.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
Unread 11-10-2013, 00:33
I am Dave! Yognaut
AKA: Brian Bray
Rookie Year: 2010
Oh well I don't know. Just try pinging everything from ".1" to ".10" at least one is bound to work (or not)
Unread 11-10-2013, 11:19
Programmer
Rookie Year: 2012
We set the IP of the cRIO to 10.46.45.2 and the IP of the computer to 10.46.45.5 and 6.
Unread 24-10-2013, 14:45
Programmer
Rookie Year: 2012
-press /enter/
-press /enter/
We tried pinging and 10.46.45.9 was the only one that was successful. Our computer is set to 10.46.45.9; did it just ping the computer?
Unread 24-10-2013, 16:57
Software Architect
Yes, I'd say you just pinged yourself. However, that's the address defined for the wireless network adapter. Are you trying this using a wireless connection, or a wired one? It's never a good idea to try to reimage a cRIO over Wi-Fi; too much can go wrong.
Unread 10-10-2013, 23:44
Programmer
Rookie Year: 2012
Well we used NI MAX to re-format and reinstall the software to the cRIO because the status light was showing a software blinking error. There were no compressed folders used. NI MAX was supposed to do the install without the need for extraction of any files.
  #15   Spotlight this post!
Unread 11-10-2013, 00:08
Tom Line's Avatar
Rookie Year: 1999
What IP address did you assign to the cRIO in NI MAX?
