Go to Post Inspiration is created by a vision and is reinforced with success. - rourke [more]
Unread 14-10-2013, 17:57
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
Re: GPS at FRC Regionals?
I can't think of a reason why having April tags you put up at your driver's station window (think poster board size) would be against any rules. If you tell your robot which driver station you're at, you should be able to see it. Just hope your drivers can see!
Unread 14-10-2013, 19:16
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
See T22.E.i and ii
Unread 14-10-2013, 20:10
EricH's Avatar
Happy Birthday! EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Originally Posted by Nate Laverdure View Post
See T22.E.i and ii
Just so we're all aware of the full relevant text of the referenced rule...
T22
The only equipment, provided it does not jam or interfere with the remote sensing capabilities of another Team, including vision systems, acoustic range finders, sonars, infrared proximity detectors, etc. (e.g. including imagery that, to a reasonably astute observer, mimics the VISION TARGET), that may be brought in to the ALLIANCE STATION are as follows:
A. the OPERATOR CONSOLE,
B. non-powered signaling devices,
E. devices used solely for the purpose of planning or tracking strategy provided they meet all of the following conditions:
i. do not connect or attach to the OPERATOR CONSOLE
ii. do not connect or attach to the FIELD or ARENA
iii. do not connect or attach to another ALLIANCE member
iv. do not communicate with anything or anyone outside of the ARENA.
Mr. Lavedure is using the April Tag as a device "used solely for the purpose of planning or tracking strategy". However, doing so completely misrepresents its real use: as a sensor target. It's not for tracking strategy at all!
As a sensor target, it should be classed as a non-powered signaling device (it is signaling a location, to any robot that happens to see it and be able to read it), and thus be subject to T22-B, rather than T22-E. T22-B passes it in as equipment that may be brought into the Driver's Station.
As it is attached to the Operator Console, and could theoretically be small enough to be the back pattern of the laptop, it could also theoretically be counted as part of the Operator Console... but that's unnecessary as it's already in.
This assumes that no April Tags exist in the field itself; should there be one or more, T22 takes over and kicks it out under mimicking part of the field.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 14-10-2013, 20:39
FRC #2363
Team Role: Coach
Rookie Year: 1999
Good point Mr. Husmann; I retract my comment
