Re: Keeping drive motors cool
Most likely from the bad history of the cases shorting out in the 775's in the past few years. We avoid using them in our designs for this reason.
We are running the 550s on a 4:1 I believe(might be a 5:1, I will check later). We chose 550s over the 775s because we didn't want to deal with the case shorting problem.
So the 4:1 is a fairly good match in that situation. |
I can't really speak to the case short issue, as I've never seen a 775 case short, only a AM PG-71. However, I've heard through the grapevine (was this you, Adam?) that since 775s are a less common can size, China has more trouble manufacturing them correctly. Perhaps now they have a bit more experience, they're manufacturing them with fewer case shorts. |
The 775-18 at 12 volts has 60% more stall torque than the 550. |
We cook CIMs in drive practice, we're planning doing fans for the next season.
For the speeds we gear, in back to back elims we also get a little hotter than we like. We aren't failing CIMs, but it'd be nice if they were cooler. There is also nothing inherently wrong with adding a 550 alongside two CIMs. Many teams avoid 775s because the widespread case shorting issues in 2011. It seems like they're failing at a low rate now, but many teams will likely never use them again. Be a little less deadset in your own thoughts, and a bit more accepting of what other people are doing. Quote:
#10
Yeah, extended drive practices can really heat CIM's up.
When we run a series of practice matches, or back to back elims, or just trying to repeat maneuvers over and over again, it can take some time for those to cool down. I've heard some teams use ice packs, not the most elegant solution but it seems effective. Last edited by Abhishek R : 18-10-2013 at 16:12. |
