Go to Post From what I've seen in FIRST, teams that copy generally always learn something from it, and if they don't, the copy they produce is of much lower quality than the original. - TheOtherGuy [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 23-06-2002, 22:52
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
bridge specs
Posted by Chuck DeVore at 1/13/2001 5:44 PM EST
Other from Ckark Magnet High School sponsored by NASA.
I'm concerned that the bridge specs may be incorrect. I played with the bridge in New Hampshire and there was virtually no horizontal slop. If you follow the blueprints for the angle iron channel on the bottom of the bridge (#A1), you end up with approximately a 6 1/4 inch channel around a 3 1/2 in (4 x 4) board. Not only is there slop, but because the horizontal faces of the angle iron are "inside", the rocking motion of the bridge causes these parts to "jump" on and off of the 4 x 4. It would "feel" right if the angle iron were reversed so that the horizontal side is outside, creating a flat channel approximately 4" wide.
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Team 111 Picture archiver 2001 18 24-06-2002 00:50
Wedge and Solenoids archiver 2001 3 24-06-2002 00:17
The bridge ... moves? archiver 2001 3 23-06-2002 23:04
Using Base 36 "Compression" For Easier Scouting and Other Interesting Tidbits Adrian Wong Rules/Strategy 9 21-09-2001 20:28
