Pneumatic help
Posted by Josh Vetter at 1/13/2001 9:28 PM EST
Student on team #548, Robostangs, from Northville High School and BOSCH. I am on a rookie team, and we just got our pneumatics kit today. We already have some ideas of what to do with it, but none of us are all that familar with the systems we got. Can anyone give us some information about using them, or post a link to info. Thanks |
Make the display board...
Posted by Joe Johnson at 1/13/2001 10:24 PM EST
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems. In Reply to: Pneumatic help Posted by Josh Vetter on 1/13/2001 9:28 PM EST: I recommend that you make a display board similar to the one shown in the flyer that came with the kit. This will show you how you have to plumb these things to make them work. Chief Delphi 6 will definitely use pneumatics this year. This is a milestone of sorts because we have barely given them a second look since our rookie year when they let us down and we had to do a major redesign to get our robot even to function. This year they look very good, very good indeed. Joe J. |
Re: Make the display board...
Posted by Josh Vetter at 1/13/2001 10:50 PM EST
Student on team #548, Robostangs, from Northville High School and BOSCH. In Reply to: Make the display board... Posted by Joe Johnson on 1/13/2001 10:24 PM EST: Thats what we started to do. The picture isn't very clear, but I think we have it hooked up right. Is there a way to operate the solenoid valves without using the robot controller? We got most of the pneumatic setup done, but the rest is not ready yet, and we want to test the pneumatics, and start working with them. Thanks Josh : I recommend that you make a display board similar to : the one shown in the flyer that came with the kit. : This will show you how you have to plumb these things : to make them work. : Chief Delphi 6 will definitely use pneumatics this : year. This is a milestone of sorts because we have : barely given them a second look since our rookie year : when they let us down and we had to do a major redesign : to get our robot even to function. This year they look : very good, very good indeed. : Joe J. |
Posted by Mike at 1/13/2001 11:01 PM EST
Other from Grandview Heights High School. In Reply to: Re: Make the display board... Posted by Josh Vetter on 1/13/2001 10:50 PM EST: The display board is your key. As for making the valves work there is a manual override on the solenoid (it wil be a little whie or organge button) Push it and the valve shifts. You will also find in the pnuematics catalog a website called www.fpda.org and a user name and password. There you can find pnuematics people close to you who can help you (distributor locator map) Good Luck |
Manually operating the valves & FORCE!
Posted by Andy Baker at 1/14/2001 8:45 AM EST
Engineer on team #45, TechnoKats, from Kokomo High School and Delphi Automotive Systems. In Reply to: Re: Make the display board... Posted by Josh Vetter on 1/13/2001 10:50 PM EST: You can manually operate the valves by pressing the red (or orange) button on the valve. This helps when debugging and hand-operating the valves. As for the pneumatics in general... think of the force involved: F=PA The force of a 2" cylinder = the pressure (60 psi) x the area of the cylinder (3.14 sq.in.). That's over 180 lbs. of force... yowee. Andy B. ps... we will surely be using pneumatics |
| Who has used pneumatic wheels? | chellyzee93 | Kit & Additional Hardware | 3 | 16-02-2003 11:49 |
| Can you stop a pneumatic pump at half shaft | mjt902 | Pneumatics | 16 | 06-02-2003 11:58 |
| pneumatic system pressure | illumanat'i | Pneumatics | 6 | 31-01-2003 00:46 |
| How can i mount a pneumatic piston to a pvc pipe!?!?! | archiver | 2001 | 4 | 24-06-2002 01:11 |
| More than 2 pneumatic tanks? | kangarue23 | Pneumatics | 10 | 01-05-2002 12:14 |
