Go to Post Didn't know the details about the battery. In the past it was just a black (grey) box with two terminals...use...recharge...use..recharge. - cbolin [more]
Unread 15-10-2013, 19:38
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Rookie Year: 2010
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Gearbox not turning properly
Recently, after taking the gearbox apart to diagnose a different issue (which turned out to be crossed PWMs) we began having a problem in out gearbox (Toughhbox) where, whenever we try to run it, it makes a horribly loud sound and turns slower than it should.
We do not know the problem is in the motor or the gearbox, but we have been unsuccessful in diagnosing this issue. We have taken apart the gearbox and all the gears seen to be meshing fine, we just cannot get it to work right once reassembled.
Edit:
Other things to note: The motors turn fine when not geared to the final gear (the 14 tooth to 50 tooth.) and are turned by power from the battery. They will not turn by hand. The final gear also turns fine.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
