Go to Post it's called the Mars Rock automode (you sit there and wait for Opportunity to come along). - EricH [more]
Unread 23-10-2013, 18:27
TOPHER097 TOPHER097 is offline
FRC #0111
TOPHER097 is an unknown quantity at this point
Re: Frisbee shooter
My team used a linear design, but the properties are the same for both linear and circular designs. The key is to have as much grip/friction on the wheel and the other plate the frisbee is riding on. With these two points of contact, the frisbee will get a good spin=longer distance and higher rise. Another main thing that you will want to focus on is the compression. The compression determines the friction between the two points of contact on the frisbee. My team never got our compression perfect, but after some trial and error, you will get it right. One last key is to have the frisbee travel through the shooter will little to no friction, this is to keep the spin and speed constant throughout the shot for an accurate ending location (use a material like delrin).
Unread 23-10-2013, 00:02
rhp3794 rhp3794 is offline
Rookie Year: 2011
rhp3794 is an unknown quantity at this point
Re: Frisbee shooter
our offseason is this saturday, maybe we could ask for pneumatic wheels to a team close to us.
we are going to try changing the fence from acrylic to wood
Programming Leader
Team 3794
WinT
Unread 23-10-2013, 00:04
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Re: Frisbee shooter
We had marginal success with a radiused shooter using similar speeds in the spring, but decided to attempt to recreate team 67's incredible shooter as an offseason development exercise for our new builders. The results were incredible. While it is obviously not the only way to do the job...it works.
Whatever you end up with - don't overlook compression of the discs...that was the biggest factor affecting the performance of our radiused shooter - but it was very difficult to adjust the compression in that configuration...in a linear shooter it's just a matter of moving the fence.
https://vimeo.com/75662715
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 23-10-2013, 00:44
jspatz1's Avatar
Happy Birthday! jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Frisbee shooter
Team 1986 shooter: 2 stage
1st stage - CIM direct drive, 2008 KOP wheel (6" w/ solid rubber tread), 50 degree arc of contact against bare solid wooden fence, 1/8" of compression.
2nd Stage - Mini-CIM direct drive, 2008 KOP wheel, straight path against bare aluminum fence, 1/8" of compression. Approx. 6" of close 3-sided guiding after the final wheel.
Unread 23-10-2013, 08:16
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
Re: Frisbee shooter
In our first iteration of our shooter we had a bare polycarbonate side wall supported by aluminum. Our initial results were less than satisfactory (only a few meters). We added a tacky material to the side wall and the results were astounding. We were shooting a few meters before and with the added sidewall material we could shoot full court.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 23-10-2013, 08:50
Chris is me's Avatar
AKA: Pinecone
Re: Frisbee shooter
As a counterargument, our two wheeled linear shooter had plenty of shot consistency with a smooth polycarbonate wall on the opposite side. Our shooter was far from an optimized solution, but if you're trying to build a simple cycler, you don't need a perfectly optimized solution. You just need a consistent and effective solution.
Here's our shooter specs, if it helps you:
- Two Banebots 4 7/8" wheels plugged into two mini cims or a cim + mini-cim (honestly doesn't matter) using the AndyMark 8mm to hex adapters
- 10.5" between the tips of the wheels and the opposite wall of the shooter (so .5" disc compression)
- Polycarbonate on the opposite side of the shooter. I've heard from MANY teams that wedgetop tread or other grippy material works well, so consider that an option too, but you might not need it.
- Plastic strips above and / or below the shooter barrel such that frisbees sliding through are physically constrained in the shooter. Basically what this does is it forces the frisbee to contact both wheels rather than lifting up between the wheels and not getting full contact. This dramatically improves vertical consistency.
We used an aimable shooter so I can't tell you if this consistently fires the exact same height over 1,000 shots, but if everything was working all 4 discs would hit almost the exact same place every cycle. This definitely isn't the best way to build a shooter, but "done" is better than "perfect".
Unread 23-10-2013, 09:55
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Frisbee shooter
Perhaps your larger-than-normal compression mitigated to some extent the sliding due to the polycarb fence.
Unread 23-10-2013, 19:33
Rookie Year: 2011
Re: Frisbee shooter
Finally we shoot as we wanted, we use the mini CIM and the CIM, and the wheels 6" diameter. we change the wall with wood.
We try to power the wheels at different speeds, the first motor (mini CIM) has a regulate speed and then the CIM the maximum speed.
We almost reach 110" hight at 6 mts distance.
ID:	15352  Click image for larger version
ID:	15353  Click image for larger version
ID:	15354  Click image for larger version
Programming Leader
Team 3794
WinT
Unread 23-10-2013, 19:46
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is online now
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Frisbee shooter
How are you going to feed the shooter?
(Hawaiian Kidsth post!)
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 23-10-2013, 21:14
jspatz1's Avatar
AKA: Jeff
Rookie Year: 2007
Re: Frisbee shooter
Very similar to our shooter however our CIMs are switched, with the full CIM first then the mini-CIM. The mini RPM is 20% higher the the CIM, so it naturally runs faster with both running full speed. Works wondefully for us.
Unread 23-10-2013, 21:54
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
Re: Frisbee shooter
Originally Posted by jspatz1 View Post
Very similar to our shooter however our CIMs are switched, with the full CIM first then the mini-CIM. The mini RPM is 20% higher the the CIM, so it naturally runs faster with both running full speed. Works wonderfully for us.
This! flip the motors and run both on full, you might need to turn the speed down a bit if there's too much slippage the wheels will just do burnouts on the disk.
The wood probably added some much needed support. Shooter really need to be rigid, or the force will transfer to the robot instead of the frisbee.
In our 90 degree shooter(different beast), we found that using double sided tape with different thickness sheet metal/polycarb/traction material was an excellent way to tweak the compression/friction to see what gives the best the distance/accuracy.
Unread 23-10-2013, 00:22
T^2 T^2 is offline
FRC #5499
Rookie Year: 2011
T^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond repute
Re: Frisbee shooter
Hi everybody! Our team and i, are trying to build a new shooter, we tried with some youtube videos, but the frisbee doesnt have speed! How can we make a new shooter quickly? Our offseason event is on october 26th!
HELP!
I don't know what your team's situation is at the moment, but given your 2013 record (I checked The Blue Alliance) and the way you phrased your question, your team is in no to be creating a shooter.
I regret that I didn't discover this thread until today, else I would have tried to dissuade you a week earlier and saved you a week of wasted time. The other respondents to this thread have given excellent advice on creating a solid shooter, but that advice is the result of thousands of hours of cumulative experience and practice. Obviously, each individual shooter will be unique, and will need its own tuning. Your team does not have the time or experience to be able to make a consistent shooter by Saturday; the fact that you are posting today to say that you don't have a functional shooter yet only confirms my suspicions.
Your team should abandon all work on the shooter and focus on what is actually important for your robot: drivetrain and driver practice. It has been said for years, for very good reason, that a good driver on a terrible robot will consistently outperform a poor driver on a world-class robot. If you focus on training your driver, on a properly working drivetrain, for the next few days, your team has a chance of making a positive impact on your elimination alliance. If, on the other hand, you continue to work on your shooter, you will fail at both shooting and driving.
Of course, it's possible that your team cares more about creating a shooter as an engineering exercise than for competitive reasons. Even so, I, as a student in my third year of FRC, personally believe that engineering a good drivetrain is easily the most important part of creating a robot, and is by no means simple or easy.
I'm sorry if I punctured your bubble of happiness. If I could have done it sooner, I would have. In all honesty, I'm surprised no one else brought this up sooner.
Unread 24-10-2013, 11:41
TedG's Avatar
TedG TedG is offline
CAD, Design & Graphics Support
AKA: Team supporter and enthusiast
FRC #0133 (BERT 133)
TedG will become famous soon enough
Re: Frisbee shooter
How do you know they don't have a practice robot they are working with already? Maybe it was mentioned they don't and I missed it, or you just know they don't. I agree that it is sometimes wise to abandon part of the project to save the baby. Worth asking before you burst bubbles IMO.
Bonny Eagle Robotics Team - BERT 133
2009-2010: Mentor, 2010-2013 Advisor/Mentor, 2013-Present: Mentor/Cad & Graphics Support
2010 - GSR: Excellence in Website Design
2011 - GSR: Motorola Quality Award
2012 - Mainely Spirit: Spirit Award, Human Player Award- GSR: Gracious Professionalism Award, Quarterfinalist- Beantown Blitz: Finalist
2013 - Mainely Spirit: Sportsmanship Award- GSR: Semifinalist, Woodie Flowers Award- PTR: Semifinalist- Beantown Blitz: Semifinalist
2014 - GSD: Spirit Award, 5th seed, Semi Finalists- PTD: 2nd seed, Finalists
2015 - Safety Animation 1st Place Award, PTD: Excellence in Engineering Award, 8th seed, Finalists, UNHD: Spirit Award, 9th seed, 6th seed Finalist Alliance Captain; Event Winner
2016 - NSD: Industrial Design Award, 3rd seed, Semifinalist- PTD: Excellence in Engineering Award, 2nd seed, Event Winner
Opinions expressed here are mine alone, and not necessarily of the team.
Unread 24-10-2013, 12:01
Rookie Year: 2011
Re: Frisbee shooter
We are glad to tell everybody who help us. that our shooter is ready!
Programming Leader
Team 3794
WinT
  #15   Spotlight this post!
Unread 24-10-2013, 12:26
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
Re: Frisbee shooter
The pictures they posted after the comment you reference was made do show what appears to be a very capable drive system with mecanum wheels. I agree: take the request at face value and don't assume.
Good luck on Saturday 3794.
