Go to Post ... my most important lessons in life all came from one place, Sesame Street. - Karthik [more]
Unread 17-10-2013, 07:33
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Electrical Connectors
With a desire to keep several of our robots past the season for demonstration...but the high cost of supplying each with a complete control system...I want to suggest that the team design and build a "modular" control unit this season with the Creo, sidecar, power distribution board, jags, and spikes. We could then modify the previous robots to accept this module and be able to switch it back and forth. They would need some kind of multi-conductor plug and jack system - and I haven't had much luck with reliability. Is anyone doing something like this? What kind of connectors are you using?
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 17-10-2013, 07:49
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
Re: Electrical Connectors
For signals, you could use something like a parallel port DB-25 to make a harness for that robot's sensors and pwm connections. You would solder all the leads to the appropriate pins on the plug(s). Last season, we used an aircraft-grade DB harness plug for our shooter deck.
For the cRIO and digital sidecar, you would keep them plugged together with a regular harness set. For power, we've put Anderson Power Poles between the motors and motor controllers for ease of rewiring.
We've used velcro on Baltic birch plywood to hold down all our motor controllers, cRIO, and digital sidecar.
What you are asking is actually a fairly good design practice for a competition robot, even if you had extra control system in your inventory. The ease of access and serviceability will save you a huge hassle later on.
Unread 17-10-2013, 08:07
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
Plus, we usually create our drive base first, then we find that we have to cover everything up with a big towel when we drill or cut on a new superstructure. It would be nice to pull all the sensitive electronics out for protection.
Thanks for those suggestions...I'll look into that.
Unread 17-10-2013, 08:08
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Please remember that the Anderson Power connectors can be assembled into blocks and are also available in different colors. We have assembled a connector with more than 15 circuits in the past for removable appendages.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 17-10-2013, 08:11
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
For the past few years, we've used Anderson PowerPoles between the electrical board and the rest of the robot. It lets us build the board separate from the robot, so it only gets attached at the very end of the build season with a couple of bolts and plugging the connectors together. This is also making it easy for us to swap out the board this fall as an Alpha Test team, so we can hook up a completely new control system!
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 17-10-2013, 08:25
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Here is a link to some of the Anderson Power Connectors we have used. You can order new pins (contacts) and reuse the cases on wires no longer being used to help offset costs for future builds.
The crimper that we use for these connectors is a great one.
You can also connect the blocks in such a way that they only fit in one orientation instead of using different color cases. This eliminates the "need" for stocking different color cases.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 17-10-2013, 08:26
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Interesting problem here.
Designing a control board (sizes, mounting holes ect) before kickoff to be used on a competition robot doesn't appear to satisfy R16 per 2013 rules.
R16
ROBOT elements, including software, that are designed or created before Kickoff are not permitted, unless they are publicly available prior to Kickoff.
You can get around this by say, posting a CAD model on Chief Delphi, but be aware of it.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 17-10-2013, 08:32
tim-tim's Avatar
AKA: Tim Miedzinski
No one says that the board will be the in terms of layout and components. Rather if you know the old robot's control board mounting configuration, you can design a new board that incorporates both the old mounting configuration and the new mounting configuration. It may even be possible to use the same mounting holes for both robots. I don't think this violates the rule, or the intent of the rule.
Now if you were taking last year's (old) board and installing it in the current season's (new) robot, this would be an issue. Although, I see nothing wrong with you using an old board on the robot for testing purposes until you can get a finalized design for the new board.
The RoboBees
Unread 17-10-2013, 08:54
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
My plan is to do exactly this...with a twist, Use the design project as a CAD training activity in November and December. Post the design for all to use, modify, improve - then adapt it as necessary when the new game is revealed. Hopefully we can come up with something that will work with the new robot, but still operate Logomotion and Ultimate Ascent - the two bots we're keeping for demonstration purposes.
Unread 17-10-2013, 11:22
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
To fully conform to the rules: Your design can be published & reused. Physical parts (non COTS) have to be made during build season. So your mounting board can be used for development, but you should make a new board for competition.
Unread 17-10-2013, 11:33
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
Exactly...wouldn't want to build this before kickoff anyway - it might have to be waterproof! My hope is that it can be backward compatible...not that something we make now becomes forward compatible.
My main concern was finding some way to create the modular connections that would allow us to plug it in and remove it easily and reliably. The PowerPoles look like the answer!
Unread 17-10-2013, 12:07
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
I'll second Anderson Power Poles for power, but we've also been using Tyco CPCs (Circular Plastic Connectors) for signal connections with great success. You can see the catalog page here:
http://ca.mouser.com/catalog/catalogcad/646/1576.pdf
In the past we've used DSub connectors, but they required good soldering skills and weren't very forgiving. They can be found cheap though, while the Tycos will cost upwards from $10 for connectors and pins. You'll also want to get their crimping tool ($225).
Our design for the last two years has split the electrical board in two - a signal box (cRio, digital sidecar, etc.), and a power box, each of which can be removed quickly from the robot. The system still needs some work, but it has been a big plus for modularity, and showing students how things should be done in the "real world".
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 17-10-2013, 13:31
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
One option is to use D-subs that work with ribbon cable such as the example below. I have always used a vise to gently "crimp" connectors such as these for the prototypes I have worked on.
www.digikey.com/product-detail/en/1658612-3/AFR15B-ND/825359
If I recall correctly, many of the cRio interfaces will work with connectors that also take the same type of ribbon cable.
Unread 17-10-2013, 13:52
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Link not found...
Jim
  #15   Spotlight this post!
Unread 17-10-2013, 08:20
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
One of the TechnoKats' best-designed robots in recent memory indeed used a DB25 for sensor connections. That even let us use an extension cable between the control box and the robot a few times when we wanted to test some code while the robot was surrounded by people doing mechanical work.
A couple of blocks of Anderson PowerPole connectors were the disconnect for the motor power wires. If we do that again, we'll make sure the person responsible understands the importance of using the little locking pins between them.
