Bridge Width Question
Posted by Brian at 1/14/2001 12:35 PM EST
Engineer on team #226, Tech CReW, from Troy High/Troy Athens.
Does anyone know if there is a problem with the bridge width on the blueprint. If you build it using 16" on center for the supports. The bridge would be 49 3/4" wide including the metal on the outside. They say on the print 3X1'4" on center. Has anyone else had this problem. Thanks.
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
