Go to Post I believe that your career should support your dreams. - Tytus Gerrish [more]
Unread 10-19-2013, 07:41 PM
mkaa00x's Avatar
mkaa00x mkaa00x is offline
Momo
AKA: Mohammad Al-Ahdal
FRC #4627 (Iron Manning)
Team Role: RoboCoach
Rookie Year: 2012
mkaa00x is an unknown quantity at this point
Post Swerve Drive Tester
Hey Guys!
Okay So I'm here basically to submit a Java File that Helps teams attempting to use a swerve drive.
Yeah, it's a basic Java application that'll help teams who need to get going fast at competition time!
Unread 10-20-2013, 03:54 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Swerve Drive Tester
Originally Posted by mkaa00x View Post
Hey Guys!
I'm no Java guru, but it appears to be jibberish. Perhaps I'm doing something wrong.
File Type: txt MD5_zip.txt (170 Bytes, 19 views)
File Type: txt MD5_class.txt (213 Bytes, 11 views)
File Type: txt DIR_class.txt (185 Bytes, 14 views)
Unread 10-21-2013, 11:45 AM
jlmcmchl jlmcmchl is offline
FF - The Breakfast Company
AKA: Jordan McMichael
FRC #0027 (Team RUSH 27)
Rookie Year: 2011
jlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud of
I see a program that does the trig required for a swerve drive, without showing how it's done. How does this help teams?
Field reset: Kettering Kickoff ('13, '14), Kettering ('14, '15), Bedford ('14), Woodhaven ('16), Carver ('16), Einstein! ('16)
Referee: Bedford ('15), MARC ('15, '16), Kettering Kickoff ('15, '16), Kettering District (#1&2: '16), Troy ('16)
Unread 10-21-2013, 12:03 PM
Ether's Avatar
Rookie Year: 1969
How can you tell? The jar file contains only Java bytecode (Main.class and MtrTester.class); no source.
Unread 10-21-2013, 12:31 PM
xForceDee's Avatar
xForceDee xForceDee is offline
AKA: Bart Kerfeld
FRC #4239 (Warpspeed)
Rookie Year: 2012
xForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to behold
The jar file is a program (double click to run with Java Runtime installed). I don't think the post is about source code but the program itself.
Unread 10-21-2013, 03:11 PM
Ether's Avatar
Rookie Year: 1969
Has anyone successfully run this?
If so, what am I doing wrong? (I'm not familiar with Java)
File Type: txt What's wrong.txt (529 Bytes, 14 views)
Unread 10-21-2013, 03:20 PM
BigJ BigJ is offline
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Try "java -jar <jarfile>". if the manifest inside the jar file was made correctly it will run the main class.
Unread 10-21-2013, 03:23 PM
Rookie Year: 2011
Yep. Java's funky like that.
Either point <jarfile> to the absolute path, or the canonical path.
Last edited by jlmcmchl : 10-21-2013 at 03:24 PM. Reason: clarification on <jarfile>
Unread 10-21-2013, 03:29 PM
Ether's Avatar
Rookie Year: 1969
Thanks, that worked. That is to say, the program ran. But the program doesn't seem to work properly - doesn't seem to give correct angles and speeds.
Would the OP please join this dialog?
Unread 10-21-2013, 04:31 PM
xForceDee's Avatar
AKA: Bart Kerfeld
Rookie Year: 2012
Also, if you are not one to use command line arguments, to open the file, right click on the jar file, select open with, and select choose default program. From there, navigate to Java (either in Program Files or Program Files (x86)). In there, select jre6 or jre7 whichever version you have. Then go to the bin folder and double click on javaw.exe. This will open the program and set .jar files to open by default using the correct method in the future.
Unread 10-21-2013, 04:56 PM
mkaa00x's Avatar
Momo
Rookie Year: 2012
OP's Back!
Haha sorry, it's not really supposed to display the algorithm behind if, but if you'd like, I could post a link to the algorithm I used to create it as well as my source code. It's a very simple program with a few bugs that are yet to patch up, I simply realized that there wasn't a program like this out there yet and so I decided, why not post it? (there is an excel file somewhere out there however that works like a program which I was grateful for )
Unread 10-21-2013, 05:27 PM
mkaa00x's Avatar
Momo
Rookie Year: 2012
Here is the Java source.
Open it up in Netbeans to view the files
*Edit*
Re done Program, still not perfect, gives rounded values.
*/Edit*
Unread 10-21-2013, 06:01 PM
Ether's Avatar
Rookie Year: 1969
*Edit*
*/Edit*
The equations in there look hauntingly familiar.
Unread 10-21-2013, 06:06 PM
mkaa00x's Avatar
Momo
Rookie Year: 2012
I got mine from here
http://www.chiefdelphi.com/media/papers/2426
I actually used to look directly onto the PDF and not find who it was made by, but now that I know, credits to you man *I just put it in a program *
P.S. and Lol, Hauntingly familiar
P.S. again, also that excel sheet was yours 0.o Creds to you, again!
LAST P.S. (I hope) I'm afk a lot, so if I don't realy, it's probably because I'm AFK
