Go to Post Didn't you hear? After Atlanta, they aren't having nationals anymore. - Joe Ross [more]
Unread 22-10-2013, 17:07
scuba1000 scuba1000 is offline
AKA: Jack Breen
FRC #1661 (The Griffitrons)
Team Role: Mechanical
scuba1000 is an unknown quantity at this point
Designing a Planetary Gearbox to increase speed?
I have been researching ways to design a planetary gearbox. It seems that the main configuration of the gears is to have the ring gear fixed, output the rotation of the planet gear carrier, and use the sun gear as the input. This would produce a reduction.
I have found little information about using a planetary gearbox the other way around to multiply speed. Is it commonly done or is there some other alternative to this? The design would be to have the ring fixed, the gear carrier as the input, and the sun as the output. Is the ratio just the reciprocal of the normal ratio.
I did see that the Wikipedia article on planetary gearboxes said that the ratio for what I'm talking about is 1+ Nring/Nsun. But it said a citation is needed, so I just wanted to double check.
Unread 22-10-2013, 17:17
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
Team Role: Coach
Rookie Year: 2011
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Re: Designing a Planetary Gearbox to increase speed?
The most common example is an old-school pencil sharpener (although maybe not as common anymore). The handle is attached to the carrier and the planets spin relatively fast compared to the crank handle, which causes several rotations of the sharpening cylinders around the pencil. There is no sun gear in this case, as the desired output is shearing of pencil pieces, rather than shaft output speed.
Yes, the ratio with a fixed ring gear with the sun as the output is 1 : (1+Nring/Nsun). You can do any of the 6 combinations of sun, carrier, or ring fixed with the other 2 being input and output. The math gets kinda fun, and I'm sure I could dig up an old textbook to cite. Certain configurations even produce backwards rotation.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 22-10-2013, 17:46
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Ns * Ss + Nr * Sr = (Ns+Nr) * Sc
where N is number of teeth and S is speed, s, r, and c are sun, ring, and carrier.
If the speed of the Ring (Sr) is zero then:
Ns * Ss = (Ns + Nr) * Sc
or
Sc= Ns / (Ns + Nr) * Ss
(This is for a simple planetary)
Unread 22-10-2013, 18:12
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
or
As Tom is showing, technically, all 3 can spin at a given rate. One of the more recent and famous versions of this is the drivetrain of a Prius:
http://en.wikipedia.org/wiki/Hybrid_Synergy_Drive
In your scenario, you are used to seeing a PSR or Planetary speed reducer. This is usually because you have a high speed source (like an electric motor) and want high torque to do some useful work.
Windmills are the opposite and have PSI or planetary speed increasers as they blades produce a lot of torque, but the generator wants higher speeds.
Unread 23-10-2013, 20:45
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
From Wikipedia
Originally Posted by Wikipedia
This limited gear-ratio set, forces the engine crankshaft to rotate at speeds where the ICE is less efficient, i.e. where a liter of fuel produces less joules.
Does this make sense? Does a limited gear-ratio set on a ICE produce incomplete combustion?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 23-10-2013, 20:58
DonRotolo's Avatar
Back to humble
FRC #0832
I did not check the article, but it is a fact that certain IC engine speeds are more efficient than others. Depends on the engine of course but efficiency generally peaks around 2500-3000 RPM. If you put a stupid gear ratio in you can force efficiency down.
Unread 23-10-2013, 21:03
Imaginary Friend
AKA: Kevin Li
Team Role: Student
You can force efficiency down, but does a litre of fuel produce less joules as stated? I assume this is only possible due to incomplete comubstion?
Kevin Li
596 - Sciclones
Unread 23-10-2013, 22:00
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
No. It produces fewer joules.
The joules being referred to are mechanical output joules at the engine crankshaft, not joules of combustion heat.
Unread 23-10-2013, 23:58
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
I'd presume that fewer joules of the chemical are released at all--IE some of those joules are turned into entropy.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 24-10-2013, 09:58
Ether's Avatar
Rookie Year: 1969
For a given required mechanical power output at the engine crankshaft, there is a continuum of engine_speed + fuel_flow_rate combinations which will produce that power. Only one of those pairs minimizes the fuel_flow_rate.
Unread 25-10-2013, 07:02
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Team Role: Leadership
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
Engine efficiency is not (necessarily/generally) a function of incomplete fuel combustion. Engines do not provide 100% of the energy produced by burning fuel as useful mechanical energy. The balance of the energy is released as heat.
A modern gasoline engine has an efficiency typically in the range of 25-30%.
Engines operate most efficiently within a certain rpm range. This provides the connection between gear ratios and engine efficiency.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 24-10-2013, 18:37
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
From Wikipedia
Here is a link to some BSFC maps:
http://ecomodder.com/wiki/index.php/...on_(BSFC)_Maps
BSFC or Brake Specific fuel consumption shows how much fuel is consumed for each useable work unit produced at a given operating point.
If you look at the:
Mercedes Benz 300SD OM617 5 cylinder turbo diesel map,
You will see behaviour that Don R is talking about. where there is a sweet spot to run the engine from a (fuel in)/(work out). For that engine, the sweet spot is between about 1900 and 2600 rpm and the engine is about 60-90% fully loaded.
For gas and diesel engines, the general rule of thumb for peak efficiency is around 50% max rpm and at and above 50% load. This is a very general statement.
If you had a 1 speed gearbox, you would figure out the most important attribute,a nd size your gearbox to match that (acceleration, top speed, fuel economy). For Supermileage, we had a single speed drivetrain.
If you want it all, then you would go for a CVT or continuously variable transmission that would (in theory), give you the optimal ratio for whatever scenario you are driving. These gearboxes tend to have other issues (efficiency, cost, longevity, weight....).
The Toyota Hybrid system does a really good job of acting like a CVT without some of the draw-backs, and with some other benefits. Its not "perfect", but it is a really good system for a car, and a pretty neat one to figure out.
BTW, you can replace the generator/electric motor with Hydrualic pump/Hydrualic motor and achieve a similar set up... Of pressurized air... Or... Check out this Dana HVT. It is a 3 range IVT (infinitely variable transmission) powersplit...
http://www.youtube.com/watch?v=jsgw7ozlfJ0
Unread 24-10-2013, 19:00
Ether's Avatar
Rookie Year: 1969
Does anyone know: What's the word on the street about the CVT in Nissan Altima concerning the issues mentioned above?
Unread 24-10-2013, 21:31
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Nissan and CVTs have a pretty long history, so a little searching should give you some background. I believe they use a "push style" belt which is pretty neat. Check out "Van Doorne" for some history on the push belt.
  #15   Spotlight this post!
Unread 22-10-2013, 17:53
AKA: Jack Breen
Excellent. Thank you both.
