Go to Post Kids should already be motivated to build the best robot they can, and learn as much as they can. They shouldn't need extra incentives. - Matt382 [more]
Unread 25-10-2013, 16:56
Alika Shukurova Alika Shukurova is offline
Likasha
FRC #0304
Rookie Year: 2013
Alika Shukurova is an unknown quantity at this point
problem with getting power
We are getting power to motor controls and sidecar but are not receiving power to crio. I tested the crio out on a different power board and it worked.
Do we need to replace the power board?
Unread 25-10-2013, 16:59
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: problem with getting power
Did you put a multi-meter on the 24v output of the non-working power distribution panel?
Is the 24v LED on the non-working PDP showing bright green or is it dark?
Is anything else connected to the 24v output, e.g., solenoid power?
Did you test with the same 24v wires/connectors on both the working PDP and the non-working PDP?
aryker's Avatar
aryker aryker is offline
FRC #0868 (TechHOUNDS)
aryker will become famous soon enougharyker will become famous soon enough
Where are you connecting your cRIO on your power board?
Unread 25-10-2013, 17:03
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Rookie Year: 2012
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
Not necessarily. Depending on how you transferred the cRIO to the other PD board for testing power, you might just have a loose connection. If you have a multimeter handy, I would suggest checking the voltage coming out of the cRIO dedicated port on the PD board. If you are reading the correct voltage, you probably just have a loose connector. If not, it may be something far more serious.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
Unread 25-10-2013, 18:33
Likasha
FRC #0304
Rookie Year: 2013
Thank you,
We found a bent pin in the board and it works fine now.
