Go to Post Andy Baker told me this one: "Do what people wouldn't talk about when you win the nationals."- Nuff Said - Matt Attallah [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 23-06-2002, 23:02
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Bridge Mass Properties
Posted by Dodd Stacy at 1/16/2001 12:02 AM EST
Engineer on team #95, Lebanon Robotics Team, from Lebanon High School and CRREL/CREARE.
We measured our bridge properties, and here is what we found, for those teams who are taking a mathematical approach to their design effort. Our bridge weighs 214 lbf, including the weights but not including the sexy aluminum diamond side plates (not our style), and we hadn't yet put on the two steel lip plates at the bridge ends. More important, we measure the bridge CG height - including the weights - at about 6" above the top of the bridge deck.
The measurement technique involved balancing the bridge on the end lip and measuring the small angle of the deck from vertical with a level and protractor, so the error may be significant, but there it is for what it's worth. Put your robot weight and its CG height into play with an inverted pendulum, and see how fast the system will pitch forward and how fast you have to correct your position, if your robot wants to balance on the bridge. Good luck, all.
Dodd
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Team 111 Picture archiver 2001 18 24-06-2002 00:50
Wedge and Solenoids archiver 2001 3 24-06-2002 00:17
The bridge ... moves? archiver 2001 3 23-06-2002 23:04
Using Base 36 "Compression" For Easier Scouting and Other Interesting Tidbits Adrian Wong Rules/Strategy 9 21-09-2001 20:28
