Go to Post Never quit, never give up, never say die! - Cascade [more]
Unread 28-10-2013, 10:05
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Rookie Year: 2010
Bpk9p4 is on a distinguished road
PWM Connections
Are team is having some problems with PWM connections to the motor controller. Does any other teams have this problem and if so how have you gotten around it.
We were thinking about taking the PWM cables and making jumpers for RJ-11. Has anyone done this?
Unread 28-10-2013, 10:42
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Re: PWM Connections
If the problem you are having is merely keeping the straight header on the pins put the connector on and secure with a drop of hot glue.
It's harmless done with care and easy to undo.
Unread 28-10-2013, 10:45
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
Rookie Year: 2012
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
Re: PWM Connections
Could you be more specific with your connection issues? As in, are the PWMs not fitting right, are they falling out, not sending a signal, etc.
Unread 28-10-2013, 10:49
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Re: PWM Connections
If your problem is them coming out you can try using gaffers/electrical tape to secure connections together and to motor controllers. We done this with much success over the past few years. For trickier situations where the tape doesn't hold up you can try hot glue. We had a pwm to one of our shooter jaguars that was always coming loose during aggressive game play that we fixed with hot glue. No issues over this past weekend during some of our roughest play of the year.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 28-10-2013, 10:55
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
Rookie Year: 2007
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
Re: PWM Connections
Make sure that if you decide to start gluing things to not break Rule 65 from the 2013 game manual which says you cannot glue anything to a motor controller.
<R65>The Driver Station software, cRIO, motor controllers, relay modules, wireless bridge, and batteries shall not be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, gluing, rewiring, disassembling, etc.), with the following exceptions:
Please note that the Driver Station application is a separate application from the Dashboard. The Driver Station software may not be modified, while teams are expected to customize their Dashboard code.
A. User programmable code in the cRIO may be customized.
B. Dip switches on the cRIO may be set (applies to cRIO-FRC only).
C. Motor controllers may be calibrated as described in owner's manuals.
D. Fans may be attached to motor controllers and may be powered from the power input terminals.
E. If powering the compressor, the fuse on a Spike H-Bridge Relay may be replaced with a 20A Snap-Action circuit breaker.
F. Wires, cables, and signal lines may be connected via the standard connection points provided on the devices.
G. Fasteners may be used to attach the device to the OPERATOR CONSOLE or ROBOT.
H. Labeling may be applied to indicate device purpose, connectivity, functional performance, etc.
I. Brake/Coast jumpers on motor controllers may be changed from their default location.
J. Limit switch jumpers may be removed from a Jaguar motor controller and a custom limit switch circuit may be substituted.
K. If CAN-bus functionality is used, the Jaguar firmware must be updated as required by FIRST (see Rule R68-D).
L. The First Touch I/O module’s firmware may be modified.
2016 (mentor/drive-coach)
Quarter-Finalist-Einstein, Winner-Carson Division Champs, Winner-10K Lakes, Chairman's Award-10K Lakes, Finalists-Lake Superior,
Winner-MSHSL Robotics Competition
2015 (mentor/drive-coach)
Finalists-10K Lakes, Finalists-Lake Superior, Finalist-MSHL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2014 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior Winner-MSHSL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2013 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior, Winner-MSHSL Robotics Competition, Quarter-Finalist-Newton Division Champs
2012 (mentor/drive-coach)
Finalists-Lake Superior, Semi-Finalist-MSHSL State Championship, Semi-Finalists at 10,000 Lakes
2008-2011 (college mentor)
2007 (driver)
Quarter Finalist-Milwaukee
Unread 28-10-2013, 12:55
Bpk9p4's Avatar
FRC #1756
Rookie Year: 2010
Re: PWM Connections
the issue is when connected to the motor controllers we do not always have a good signal. This problem only seems to be an issue when setting up the electrical system. Once we get them all working it is fine. The problem is getting them all working in the first place
Unread 28-10-2013, 13:24
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: PWM Connections
What kind of motor controllers are you using, Victor 884, Talon, Tan Jaguar, or something else? Talons take a bit of work to get the PWM connector in the slot, but once it's in you shouldn't have any trouble. Victors are notoriously difficult to make a good PWM connection unless you have years of experience doing it right. Jaguars are simple to plug into, but you really need to use the cable retaining hook to keep the connection from coming loose easily.
Unread 28-10-2013, 13:51
Bpk9p4's Avatar
FRC #1756
Rookie Year: 2010
Re: PWM Connections
We are using victors. Any advice on how to make this connection more robust?
Unread 28-10-2013, 14:44
Software Architect
Re: PWM Connections
Once you get the connector plugged in properly, it's usually a pretty robust connection. Some teams use a drip of hot glue to prevent it from coming out accidentally. There are also special metal clips you can use that fit under the Victor and reach around the cable to hold the connector in.
Getting it plugged in to begin with is something you'll just have to get some practice with. Make sure the pins are perfectly straight and get a feel for exactly how they fit the holes hidden at the bottom of the slot. If you don't do it just right, one or more of the pins can bend aside and miss its target. Once you know how it's supposed to feel, it will be obvious when it's done correctly.
Unread 28-10-2013, 14:49
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
Re: PWM Connections
A dab of RTV silicone or hot glue is an old and effective solution to the problem of the cables pulling out.
The more common issues is that it is possible to insert the cable and have it give the feel and appearance of being seated, but for the pins to have not actually made it into the sockets. Check the pins very carefully prior to inserting them, looking for bent or short pins. Insert them gently and perfectly straight.
Unread 29-10-2013, 09:17
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Re: PWM Connections
As others have said, hot glue is really awesome for keeping PWM Cables in Victors.
One of the best methods for doing this seems to be something like this:
  1. 1) Turn robot on, wait for communication.
    2) Verify that all speed controllers are receiving signal, if not, find the problem.
    3) Once you've verified that all of the connections are sound, apply a bit (you don't need much) hot glue to the connection at the speed controller.
    4) Verify that all speed controllers are still receiving signal.
The method above comes from doing this the wrong way a few times in school. I can remember having to remove hot glued connections a few hours after they were done because no one bothered to check connections prior to gluing. It wasn't too fun, but not all that bad either.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 29-10-2013, 12:50
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
Team Role: Teacher
Rookie Year: 2000
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Re: PWM Connections
Do you have a 3D Printer? This thread got me thinking about how to help our electronics team.
Unread 29-10-2013, 12:53
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: PWM Connections
Please see my post regarding gluing things on electrical devices...
http://www.chiefdelphi.com/forums/sh...2&postcount=99
Al
WB9UVJ
www.wildstang.org
________________________
Unread 29-10-2013, 13:33
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: PWM Connections
This sounds like some incredibly strong hot glue. Unless you are talking about encasing the connector in glue?
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
  #15   Spotlight this post!
Unread 29-10-2013, 15:26
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: PWM Connections
Neat idea. Have you uploaded your design to Thingiverse and share it with the world?
