Go to Post remember kids, never listen to Big Mike.... - Mike Schroeder [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 01-11-2013, 00:02
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Lightbulb Good use for Sonar Sensors
Hi guys,
I will be starting a VEX team and thought of this idea:
Basically, there will be an ultrasonic distance sensor placed upon a servo, to create a rotating turret. For autonomous, the microcontroller will move the servo and map out all the beanbags it detects, and the one that is closest. It will have encoders to allow the robot to home itself. Basically, the robot will go and pick up the closest game-piece then home itself back at the origin. Then it will calculate a trajectory to get the game piece into the location required. The robot will do this whole thing autonomously.
I have attached a document about what I will be doing
So, what do you guys think?
This post is about this type of object tracking. This will actually be used on vex, though a similar system can be used on FRC. This will allow robots to navigate and pick up game pieces autonomously. However, since this isn't visual, it wouldn't easy to integrate this with the shooter, unless you want to calculate the speed at which the frisbees are heading out.
Unread 01-11-2013, 00:28
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Re: Good use for Sonar Sensors
I've done this before on a mobile robot that mapped and explored a maze.
Mounted an ultrasonic and IR rangefinder onto a servo turret. As the robot drove through the maze, I tracked the current position using wheel encoders and then translated all of the mapping values to an absolute position map of the environment. After doing a ~270 degree scan, it would look for the first gap in the walls/objects large enough to drive through. If it ever hit a dead end, it would turn 180 degrees, then rescan.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 01-11-2013, 00:35
AKA: null
Rookie Year: 2012
Lightbulb Re: Good use for Sonar Sensors
Yes, I know it would be possible. However, I am wanting to beat our star VEX team who came fifth in nationals. I want to come First Place! So, how did you do this maze solving? How much RAM did it require?
