Go to Post Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him. - sciencenerd [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 23-06-2002, 23:05
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
How do you connect optical sensor?
Posted by Joe Ross at 1/17/2001 5:01 AM EST
Engineer on team #330, Beach Bot, from Hope Chapel Academy and NASA/JPL , J&F Machine, and Raytheon.
The picture on page 12 of the robot section shows the black and white wires connected directly to the switch inputs on the Robot Controller. I was looking at the data sheet included with the sensor (you can also find it online: http://www.baneng.com/pubfiles/63908.pdf) and saw that the sensor requires a load on the black and white wires. My question is, does the robot controller provide this load, in which case we wire the sensor exactly as is shown in the competition manual, or do we need to provide a load?
Has anyone hooked their's up yet?
Joe Ross
Beach Bot, Team 330
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: How do you connect optical sensor?
Posted by Tom S. at 1/17/2001 6:33 PM EST
Student on team #177, The Bobcats, from South Windsor High School and International Fuel Cells & ONSI.
In Reply to: How do you connect optical sensor?
Posted by Joe Ross on 1/17/2001 5:01 AM EST:
Joe-
Without looking at it... i am fairly sure that you can just hook it up exactly as it says in the manual:
Blue - Pin 3 (Ground)
Brown - +12 Vdc (From breaker)
Black - Pin 15 (Switch Input 3)
White - Pin 16 (Switch Input 4)
Good luck...
Tom
PS: i have not hooked ours up yet, so i am not completely sure on this
: The picture on page 12 of the robot section shows the black and white wires connected directly to the switch inputs on the Robot Controller. I was looking at the data sheet included with the sensor (you can also find it online: http://www.baneng.com/pubfiles/63908.pdf) and saw that the sensor requires a load on the black and white wires. My question is, does the robot controller provide this load, in which case we wire the sensor exactly as is shown in the competition manual, or do we need to provide a load?
: Has anyone hooked their's up yet?
: Joe Ross
: Beach Bot, Team 330
[IMG] code is Off
optical sensor majormusic2005 Technical Discussion 1 29-01-2003 07:39
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
Find any optical sensor in catalogs? GreenDice Programming 1 13-01-2003 18:05
optical sensor archiver 2001 3 24-06-2002 02:55
Optical range sensor Ben Mitchell Technical Discussion 9 12-01-2002 00:11
