Go to Post [on reputation] They're just dots. - Brandon Martus [more]
Unread 03-11-2013, 00:56
valkyrie2240 valkyrie2240 is offline
FRC #2240
valkyrie2240 is an unknown quantity at this point
Shifting Gearboxes
My team is thinking about using shifting gearboxes this coming season. This is the first season we've really deviated from the kit chassis and kit gearboxes. Any advice about shifting gearboxes and/or gearboxes in general?
Unread 03-11-2013, 01:24
Andrew Lawrence
Posts: n/a
Re: Shifting Gearboxes
Shifting is a very powerful tool that is up to driver preference. Personally, I don't run a shifter unless my specific strategy requires a really low gear (~4 ft/s), or a really high gear (~19+ ft/s). A single speed 3-CIM gearbox at ~16 ft/s is my favorite setup to run because most of the time I really don't need shifting, and the extra acceleration and power from the extra motors makes the single speed just as powerful, and mathematically you gain the biggest benefit from the extra motors at that speed.
Just my $0.02.
Unread 03-11-2013, 01:25
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Searching around will find you a treasure trove of advantages, but here's a useful thread for disadvantages and look fors when shifting.
http://www.chiefdelphi.com/forums/sh...d.php?t=109959
Pay attention to the date of the thread. This was before teams had ever used ball shifters in an official FRC match, because they had been released after the 2012 season.
While most information in the thread is general and regards shifting in general, some posts are specific to AM super shifters, which where the COTs shifting gearbox of choice at that point in time.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 04-11-2013, 10:57
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
Rookie Year: 2012
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
We use double solenoids for shifting.
Unread 04-11-2013, 11:04
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Why not use singles? Doubles waste an extra relay output.
Unread 04-11-2013, 11:21
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by Andrew Lawrence View Post
...and mathematically you gain the biggest benefit from the extra motors at that speed.
Would you please clarify what you meant by that?
Unread 04-11-2013, 12:45
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Double solenoids let you maintain the gear selection when the robot is disabled. That can be important for autonomous mode, where you can choose in advance which gear to start in and not have a problem with the gear not being engaged at first.
Unread 04-11-2013, 13:33
AKA: Ethan
Rookie Year: 2012
Exactly.
Of course, it works fine with a single solenoid, albeit less efficiently.
Unread 04-11-2013, 13:39
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Why not just pick which way the cylinder defaults to with a single solenoid?
I dont see an advantage for a double solenoid in shifting.
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 04-11-2013, 15:13
Software Architect
You mean physically swap the pneumatic tubing if you want to start in the other gear? That'll reverse the gear selection for everything.
Unread 04-11-2013, 15:31
AdamHeard's Avatar
Lead Mentor
Which you presumably need to do once per season...
Unread 04-11-2013, 15:58
Software Architect
Depending on the game, it could make sense to run some autonomous routines in high gear and others in low gear (2007 was one such game). That's swapping defaults potentially once per match. Requiring a physical reconfiguration of the pneumatics also removes the option of selecting the most appropriate routine at the last possible moment, since you don't want to be unplugging the tubing while the system is pressurized.
Another risk of using single solenoids for gear selection is the potential for a brief "disable" in the middle of driving. There are some things you don't want to change state when that happens, and I'd argue that the gear ratio is one of them. Our 2005 robot had a couple of near-tumbles when downshifting because of the high center of mass when carrying a game piece, before the drivers learned not to do that.
Unread 04-11-2013, 16:26
AdamHeard's Avatar
Lead Mentor
Ah, I see your point there.
I'd argue in most games that's not necessary, and the single provides piece of mind in that the driveteam isn't responsible for setting/checking gear before each match.
As for the brief disable, we generally default ours to high gear.
Your comments are valid overall, but in the general case we'd stick with single. I do see the validity of your points now though.
Unread 04-11-2013, 17:22
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
Team Role: Mechanical
Rookie Year: 2011
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
We always use a double solenoid, and we also use plumb both shifters to one valve so they throw at the same time. Please remember to USE PNEUMATICS TO SHIFT. Servo shifting is pure garbage and wont work under the the slightest pressure against the side of a dog, such as when pushing.
We usually start in low gear, and use high gear when we want to go really fast.
We have never tried using ball shifters, but since we have familiarity with the dog shifting style used in AndyMark gearboxes, and it has proved reliable so far as a shifting method, that probably won't change. Dog shifting is proven and tested, but ball shifters have been generally well reviewed as well, though they may be harder to implement in a custom gearbox.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
  #15   Spotlight this post!
Unread 04-11-2013, 20:42
Andrew Lawrence
Posts: n/a
From JVN's Acceleration calculator, I've found a speed of around 16 ft/s gains the largest time loss to travel a set distance when using 6 motors instead of 4 (Shaves off about a half a second on average). As you get further from 16 ft/s in either direction, the time difference to travel a set distance between 6 motor drives and 4 motor drives gets closer and closer to 0.
