Go to Post 12 is a dozen, 13 a bakers dozen...47 will be a delphi. - Kimmeh [more]
Unread 03-11-2013, 10:27
Jay_To_The_Be's Avatar
Jay_To_The_Be Jay_To_The_Be is offline
Programmer - MOE365
AKA: Jeremiah Batista
FRC #0365 (Team 365 - Miracle Workerz)
Rookie Year: 2013
Jay_To_The_Be is an unknown quantity at this point
Question OSC Library?
I'm currently working on a practice bot that has 6 wheels. I was wondering if anyone knows of an OSC Library compatible with the cRIO. And if there is one compatible, is there away of having something like my iPhone communicate directly with the cRIO over WiFi without having a middle man program on my laptop?
Unread 05-11-2013, 00:16
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
Rookie Year: 2011
William Kunkel is an unknown quantity at this point
Re: OSC Library?
What do you mean by OSC? Googling turns up "Open Sound Control", but I'm not sure what that would be used for on a practice bot.
Unread 05-11-2013, 11:19
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: OSC Library?
No. Nope. Impossible.
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 05-11-2013, 14:58
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Rookie Year: 2011
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: OSC Library?
I'm also not that familiar with OSC, but I do know you should be able to write software to communicate from an iPhone to the cRIO over WiFi via TCP or UDP. A quick search here on the forums should give you some more information on the network code for the cRIO, and Apple has plenty of resources on the iOS side of things such as this article.
I'm going to venture a guess and assume you're trying to control a robot from an iOS device? If you're willing to use LabVIEW, I found this article from NI on how to use the NI OSC library for LabVIEW and the TouchOSC iPhone app to control a NI RIO device: https://decibel.ni.com/content/docs/DOC-20651. Not sure if it's applicable to FRC though.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 06-11-2013, 06:05
Programmer - MOE365
Rookie Year: 2013
Re: OSC Library?
It was just for a practice bot, not for a comp bot. I was looking into OSC only because I thought it would be an ideal method of control for a little 6-wheeled practice bot. Also, my whole team uses C++, and Labview seems like it has it's own limitations. I was able to use OSC to control an Arduino robot arm last year for Science Olympiad, I was just wondering if the OSC C++ libraries are compatible with the cRIO.
Unread 06-11-2013, 07:38
Rookie Year: 2011
Re: OSC Library?
You might want to look into this library: http://www.rossbencina.com/code/oscpack
There isn't a binary library prebuilt for VxWorks (the cRIO's OS), but it looks like you should be able to incorporate the source into your project with some modifications. It already has separate network code for Windows/Unix platforms, so in theory all you'll need to do is write the network code for VxWorks, and the rest should just work.
