Go to Post but you can rest assured: I have restored the balance by letting the GDC know that I know that they know that you know they have a pattern. -Leav - Leav [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Unread 06-11-2013, 10:25
Gabe1511's Avatar
Gabe1511 Gabe1511 is offline
AKA: Gabriel Rosenberg
FRC #1511 (Rolling Thunder)
Team Role: Driver
Rookie Year: 2011
Gabe1511 is an unknown quantity at this point
Mecanum Drivetrains
Hello, my team is planning on developing a mecanum drive train to test with, and I was wondering what designs have been successful for other teams. So, what designs have yielded the most success, and where have there been failures and limitations with your designs?
Unread 06-11-2013, 10:32
Pendulum^-1's Avatar
Pendulum^-1 Pendulum^-1 is offline
Mentor
AKA: Jim Grove
FRC #1915 (Firebird Robotics)
Rookie Year: 2007
Pendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nice
Re: Mecanum Drivetrains
Limitation number one: Mecanum wheels are very easy to push. A problem on a field with well-defined chokepoints, such as the 2013 arena.
Jim Grove, Mentor
firebirds1915.blogspot.com
(2007-2017) 1915, McKinley Tech HS, Washington, DC
(2009) 2932, Mid-Pac Institute, Honolulu, HI (Rookie Season)
(2011) 2425, Hillsborough HS, Tampa, FL
(2013-2015) 4464, College Park, MD, 2013 Rookie All Star Winner and 2014 Regional Champions, Washington, DC
FIRST is not rocket science. But it is like drinking from a fire hose.
Unread 06-11-2013, 10:35
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Rookie Year: 2012
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
The Mecanum drive train that 1058 has been successful with in the past is a simple one-CIM gearbox for each wheel and a c-channel frame. When I'm not on a school computer I will edit this post and add a video my team made a couple of years ago explaining our mecanum drive and how it was field oriented (meaning that if you pushed the joystick away from you the robot always goes in that direction, no matter what orientation it is in).
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 06-11-2013, 10:48
JeremyLansing's Avatar
JeremyLansing JeremyLansing is offline
Team 967 Alumni
FRC #0171 (Cheese Curd Herd)
Rookie Year: 2010
JeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud of
For the mecanum drives Team 967 built in 2010 and 2011, we used the kit frame with four AndyMark Toughboxes (2010) or AM Toughbox Nanos (2011). It worked out pretty well for us, and although it isn't entirely required, we did use a gyro both years. I put a link to a video of our 2010 robot at the bottom of my post. You will hear a lot of opinions about whether mecanums are worth the effort, and I'm sure someone will bring up the mecanums on Einstein statistic, but if you implement them right, you can still be effective. Just don't expect mecanums to be a magic bullet that makes your robots better. Mecanums are not necessarily better or worse, they play to different abilities that need to be balanced in your decision making process. But since this is the offseason, prototype away!
Edit, added the link
http://youtu.be/fqeAReWKA6s
2015 Midwest Regional Finalists (Thanks to 2338 and 1756)
2014 Central Illinois Regional Finalists (Thanks to 4143 and 2039)
2013 Curie Division Semifinalists (Thanks to 2056 and 3990)
2013 North Star Regional Champions (Thanks to 2175 and 4607)
2011 10,000 Lakes Regional Champions (Thanks to 525 and 3642)
Unread 06-11-2013, 11:20
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
Team Role: Coach
Rookie Year: 2011
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
There are technical and strategic challenges to implement a mecanum drive effectively. I will attempt to briefly address both.
Technical - We've done mecanum for the last 2 years in 1 form or another. Our gearbox of choice is the AndyMark Toughbox Nano - 1 per wheel. I definitely recommend driving the wheel directly out of the gearbox rather than through a chain. We use quadrature encoders on each wheel and have PID tuning to make certain we control each wheel's speed, rather than just input voltage. We use a gyro on the robot to allow field oriented drive, while having an alternate robot oriented drive. Make sure that your frame is not too rigid. The robot can drive eratically if all 4 wheels are not on the ground. Our 2012 robot had what is sometimes called octocanum drive, where we switched between mecanum and traditional wheels. We designed the shifting pistons to support the robot weight on more than 3 wheels. This level of active suspension is not required, but was a side benefit in our 2012 design. Test with the robot weighed down to final competition weight - drives function differently with varying amounts of load.
Stategic - Mecanum is not better or worse than a more traditional drive. It is different. Teams who do not make strategic changes will be ineffective in using a more versatile, albiet, less pushy drive. Almost everyone understands that in a pure pushing match, mecanums will lose. What many people don't realize is that you can maneuver around a robot much more easily to avoid them or get out of a sticky situation. Driver practice is key, as the extra degree of freedom means the driver has an additonal drive component to control. Practice avoidance maneuvers around pushing robots. Practice lining up in the positions you need on the field. It pained me to see teams with mecanum drives this year driving them as a tank robot to get into a specific location, when they just needed to move sideways 6 inches.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 06-11-2013, 10:50
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
To add to Jay's post, we used 4x 30:1/11:1 supershifters with one CIM each. In the past, we have run each of a Jaguar, but we have blown out so many Jags that we have switched back to Victors.
If you want to get creative, you can do all kinds of crazy things with mecanums. For example, in 2011, 1058 built this simple 4-cim mecanum drive with a twist. Each wheel had a third mecanum plate with cut-up pieces of truck mud flap on it. This plate could be actuated into the rollers, freezing the rollers in place, but not the wheel. With these activated, the robot would be a high-traction 4WD that could push other robots around. At the press of a button this would switch to the normal mecanum drive, giving it unmatched speed and maneuverability.
Coming from one of the biggest mecanum fanboys in FIRST- have fun, drive fast, and forget the haters.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 06-11-2013, 11:07
This sounds pretty creative! Do you have pictures or videos of it in action?
Unread 06-11-2013, 11:26
Yep! They're around somewhere, i'll find them and post them tonight.
Unread 07-11-2013, 16:43
Here's the design and implementation of the Locking Mecanum Drive 1058 built in 2011. I threw in some match footage for you guys too!
With regards to what Jay said about Field-Oriented Drive, here's a video for that.
Unread 07-11-2013, 17:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
If I'm understanding this correctly, the rollers are stopped only be the pin / screw / post that goes through the 2nd hole you drilled near each rollers' axle?
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 07-11-2013, 17:36
In the first shot in the video, the new hole that is being drilled is to help hold on a piece of rubber. The wheel itself is left unmodified, and we take a third mecanum plate and put one piece of rubber on each "wing" or flange of the plate. When the piston is activated, it pushes that aluminum bar you see in the video into that third plate, which is mounted parallel to the mecanum wheel. This pushes the rubber piece into the wheel, braking the roller.
The plates are on the same axle as the wheel and are spring loaded, so when the piston retracts, the plate comes off the wheel, unbraking the roller.
Unread 07-11-2013, 17:51
I have to admit, that is a great little feature! How well did it work out for you in a real match against defense?
Unread 07-11-2013, 20:10
Very well, even though we encountered very little defense focused solely on us. We'd do a "roll", where we'd activate the traction drive, plow into the side of the defensive robot, go back to mecanum mode, and push towards the goal while rotating the robot. This would cause us to roll off the side of the defending robot and get past them. In other situations, we could just outdrive them with the agility of the mecanum wheels. The biggest advantage of the locking mecanums is if an opposing robot is pushing you sideways, you can stop dead with a push of the button and, amusingly, confuse the hell out of the opposing robot's drivers.
Unread 07-11-2013, 21:27
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
A lot of the same advantages of octocanum, though with octocanum you can do a 5:1 or greater downshift with little weight and cost built in.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
  #15   Spotlight this post!
Unread 07-11-2013, 21:04
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Talking Re: Mecanum Drivetrains
Team 1165's Mecanum Test! Mecanum is nothing but pure amazing, and it actually seems like magic, especially with the wheels covered up so no one can see them
http://www.youtube.com/watch?v=_Lrosi-WA7A
