Go to Post NASA rarely launches another rocket just so the programmers can see if they've fixed a bug. - Greg McKaskle [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
  #16   Spotlight this post!
Unread 12-11-2013, 23:54
Oblarg Oblarg is online now
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Re: Colson Wheel and AndyMark HTD Pulley
Honestly, I'm not seeing the ground clearance issue with the belt; if that were a problem, you wouldn't have people running VexPro 72t gears direct-mounted to 4'' omni-wheels, which I have seen work with no problems. Besides, if anything contacts, it'll be the flange, and given the near-redundancy of a flange in this setup anyway it's not exactly clear that there are any real wear issues with that.
Also, while it's nice to keep the traction wheel in a butterfly drive small, 3'' isn't exactly "much too big" - I've seen teams run butterflies with two 4'' wheels which worked fine and weren't particularly heavy.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
  #17   Spotlight this post!
Unread 13-11-2013, 08:15
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Originally Posted by AdamHeard View Post
Assuming 5mm pitch (GT2 or HTD), that's a 28T pulley. 1.754" PD, 1.875"
Flange diameter (per sdp-si spec). Just posting this so people have a data point to compare to.
I'm really surprised by a 1-7/8" flange on a 2" wheel. That flange is DEFINITELY touching carpet from my experience, but since the traction portion of an octonum is so rarely used I can see that not being a big issue (especially if metal flanged pulleys are used).
For future reference, I bet the c-c is small enough that if there is a flange on the pinion pulley and the belt is reasonably tight no flange is required on the traction wheel pulley.
3" is MUCH too big for a butterfly
Here's a picture of it. Hope it provides valuable information!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
  #18   Spotlight this post!
Unread 13-11-2013, 11:03
AKA: Eli Barnett
Out of curiosity, what cylinders were you using for that octanum?
  #19   Spotlight this post!
Unread 13-11-2013, 16:45
pfreivald's Avatar
A pair of 1.5" diameter, 6" stroke. Ummm...not sure if Parker or Bimba. We've got the setup down to ~50 lbs for the drive train including electronics and compressor, and absolutely as cheap as we can possibly make it. (Well under 50% the cost of our first go.)
Team 1551
I write books, too!
  #20   Spotlight this post!
Unread 13-11-2013, 16:48
AKA: Eli Barnett
Ah, that's a much larger stroke than I was expecting; our current butterfly drive is designed for 1.5'' bore, 1.5'' stroke cylinders.
  #21   Spotlight this post!
Unread 13-11-2013, 16:51
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
3928 this last year used 1.0625" Bore, 1" stroke pistons for our Butterfly Drive.
A guy who likes robots.
1625->3928->148->1296->971 oh dear
  #22   Spotlight this post!
Unread 13-11-2013, 16:53
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Just to one up Aren. We used the same bore, but 3/4" stroke.
We used 75% the air he did
  #23   Spotlight this post!
Unread 13-11-2013, 17:31
pfreivald's Avatar
We use one cylinder per side. We found that it was actually cheaper and lighter to do it that way, rather than have one cylinder per wheel pod. We don't shift between drive systems enough in any given game to give much of a thought to the extra battery drain.
Team 1551
I write books, too!
  #24   Spotlight this post!
Unread 14-11-2013, 02:30
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
For all you teams with butterfly drives, have you tried having the rear wheels in the opposite setting of the front wheels? Particularly to adjust your center of rotation for improved local maneuverability? does that even work?
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
