Go to Post Please forgive any possible profound language. - PortugazD.Ace [more]
Unread 10-11-2013, 10:12
Deliah_Duck's Avatar
Deliah_Duck Deliah_Duck is offline
Deliah_Duck is an unknown quantity at this point
Question [FTC]: Edges of Ranp
Hello!
I just have a quick question-
Is it safe to assume that the edges of the ramp will be flush with the floor? Or will there be a gap?
Thanks!
-Dee
Rookie
Unread 10-11-2013, 12:26
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Re: [FTC]: Edges of Ranp
The way the ramp is, there is a "gap" or bump up onto the wood, the wood has not been sanded down to make a smooth transition. The bump though is very minimal that any wheel really can bump right up on it... just make sure you don't have a piece of metal or plastic lower than 1/4-1/2in ish in the front of your robot.
Unread 10-11-2013, 12:31
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
To be safe you should assume the worst. It is possible that the ramp will be flush to the floor but that is not necessarily going to happen. When we built the ramp we weren't able to get it built perfectly.
Unread 13-11-2013, 19:05
DocMartin DocMartin is offline
FTC #6285
DocMartin is an unknown quantity at this point
there will be a certian level of variability from field to field. we are planning for a 3/4" to 7/8" bump between the floor and the ramp. This is common and some bots do get hung up on that. if they hit it just right.
Unread 19-11-2013, 12:24
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
The wood ramps will tend to develop some warping over time, especially with humidity changes, and serious warping is likely if the wood is painted/coated differently or unequally on both sides.
We sat some that were almost one inch gap with the floor last year at practice competitions.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
