Go to Post And THAT is why they have safety manuals. - Eria4044 [more]
Unread 13-11-2013, 20:18
DocMartin DocMartin is offline
FTC #6285
DocMartin is an unknown quantity at this point
[FTC]: Servo specifications?
We have a scoop in the works made from plexi ( very light) and we tossed a servo on thinking it would be able to raise and dump.
only after we built it and testing did we realize it was too weak!.
is there a way to figure this out using math or specs from the servo's?
Unread 13-11-2013, 20:39
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: [FTC]: Servo specifications?
Yes.
1) Take a simple postal scale and measure the force it takes to lift the scoop at some reasonable distance from the pivot point.
2) Multiply that force by the distance from the pivot to get torque. Use a consistent system of units.
3) Compare that required torque to the torque rating of the servo.
You might find this document helpful:
http://stanford.edu/~sebell/firstphysics.html
Unread 15-11-2013, 21:18
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Rookie Year: 2000
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
I dont work for servo city, but they have great info and FTC approved parts on thier website...
Here is the specs on the standard servo:
http://www.servocity.com/html/hs-311_standard.html
You might consider upgrading the servo to a quarter scale servo which is newly legal for 2013-2014 which will give you a significant increase in torque:
http://www.servocity.com/html/hs-755hb_1_4_scale.html
Another option is gearing the servo:
http://www.servocity.com/html/32_pit...rvo_gears.html
Also something that helps using servos are servo blocks that take the sideload off the servo horn (a common breaking point for servos):
http://www.servocity.com/html/standa...rvoblocks.html
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
