Go to Post Pro-tip: Friends don't let friends play defense! (in qualifications) - Mr. Lim [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 23-06-2002, 23:14
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Trig
Posted by Nick at 1/19/2001 6:07 AM EST
Student on team #240, Mach V, from Jefferson Monroe High School and Visteon.
For all you Pre Calc and above students-
Is there any way to go from arctangent (X/Y) to Sine and Cosine?
I need to use it in programming and the chip doesn't use arctangent, tangent, arcsine, or arccosine!
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: Trig
Posted by Jason Rukes at 1/19/2001 10:51 AM EST
Engineer on team #109, Arial Systems & Libertyville HS, from Libertyville High School and Arial Systems Corp & SEC Design.
In Reply to: Trig
Posted by Nick on 1/19/2001 6:07 AM EST:
I found this in the CRC Standard Math Tables Book.
Let A = Arctan(x), then
sin(A) = x/(sqrt(1+x^2))
cos(A) = 1/(sqrt(1+x^2))
sqrt is the square root function.
-Jason
#0047 (ChiefDelphi)
Problem is...
Posted by Nick at 1/20/2001 6:33 AM EST
In Reply to: Re: Trig
Posted by Jason Rukes on 1/19/2001 10:51 AM EST:
The problem is I CAN'T Let A = Arctan(x). I cannot use arctan what so ever. The function is not recognized by the BS2 chip.
#0047 (ChiefDelphi)
Re: Problem is...
Posted by Dan at 1/20/2001 1:07 PM EST
Other on team #247, da Bears, from Berkley High and PICO/Wisne Design.
In Reply to: Problem is...
Posted by Nick on 1/20/2001 6:33 AM EST:
You don't need to have the arctan function. It was mentioned just to help understand how the final answer was derived. It wasn't meant to be a line in your program.
I assume you want the sine and cosine of the angle whose tan is x/y. If you know x and y, the sine and cosine of that angle (which you'll never calculate) are:
sine = x/sqrt(x^2+y^2) and cosine = y/sqrt(x^2+y^2).
These are functions of x and y only, no angle.
Hope that helped.
-Dan
#247
#0047 (ChiefDelphi)
Re: Trig
Posted by Dan at 1/19/2001 2:32 PM EST
In Reply to: Trig
Pretty much the same as the last reply:
A (angle) = arctan(x/y)
tan A = x/y
Setting up a right triangle with x opposite A and y adjacent to A, hypotenuse becomes sqrt(x^2+y^2) and the rest follows:
sin A = x/sqrt(x^2+y^2) and cos A = y/sqrt(x^2+y^2)
This works fine if the angles you're dealing with are between 0 and 90. Is this true?
-Dan
#247
[IMG] code is Off
Inverse Trig K. Skontrianos Programming 6 13-03-2002 23:27
Vector Mathematics in PBASIC Adrian Wong Programming 10 06-12-2001 17:31
