Go to Post It's a club if you have a bunch of people who hang out and do nothing - It's a team if all you all work together and cooperate to win. - Tytus Gerrish [more]
  #31   Spotlight this post!
Unread 20-11-2013, 20:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Safer Saws
I should mention that I find it completely acceptable to cut aluminum with a carbide tipped wood blade. Sometimes a little WD40 helps a lot too. I do this all the time in miter and circular saws without any issue, so long as you go slow and wear proper safety gear. I've even cut aluminum box (and solid) with a 24 tooth blade, although something like an 80 tooth would be preferred.
  #32   Spotlight this post!
Unread 20-11-2013, 20:42
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Re: Safer Saws
Getting a little off topic, does it help to use a blade with more teeth to cut metal? Doesn't bigger teeth just end up tearing metal?
  #33   Spotlight this post!
Unread 20-11-2013, 20:49
Mr V's Avatar
Mr V Mr V is offline
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Team Role: Coach
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
Re: Safer Saws
Originally Posted by yash101 View Post
Actually, what I meant was to have a current, probably 12v, 2.5ma being conducted through you. Since this is an open circuit, nothing will flow through you. When you touch the blade, the circuit will be completed and fed into a multi-stage amplifier. This will be fed into a flip-flop that will shut down the motor and arm the brakes, immediately. The machine will shut down and will be "hard" to turn back on (Require that the fault is cleared, etc.)
However, the problem is: if you are machining aluminum, it would automatically trigger, meaning that you would need to measure resistance. I do not see how the SawStop works with metals!
The SawStop does not work with metals, nor Carbon Fiber. As mentioned there is a way to temporarily disable it. I've had to change a couple of cartridges from people attempting to use it for those materials.
The number of teeth that is optimum depends on the metal and the thickness of the metal. The harder the metal (steel) the more teeth, the thicker the material the lower the number of teeth.
All statements made on Chief Delphi by me are my own opinions and are not official FIRST rulings or opinions and should not be construed as such.
https://www.facebook.com/pages/Team-...77508782410839
  #34   Spotlight this post!
Unread 20-11-2013, 20:55
AKA: null
Rookie Year: 2012
Talking Re: Safer Saws
That makes sense. Thanks for elaborating!
