Thread Tools |
Rating:
Display Modes |
Re: Team 2471 swerve drives
Based on our swerve and 1717's, I'd say you can gear your turning faster. Easily in the 180-200 rpm range and get a responsiveness gain.
On a side note, here is a render of a future frame I CAD'd. It is built with a 110" perimeter. The swerves are 3" wide and 9.375" long. Sorry for the low quality render, but it was my first time trying to making a render. ![]() |
Very impressive drive system. Now that you have one iteration done and currently testing, you can continue to develop and make improvements to put yourselves further ahead than a large majority of teams for the 2014 season (assuming that a swerve drivetrain is beneficial next year...) Abuse it until you find what breaks!
I am curious about the Black and Decker gearboxes you used. Do you have more details on what model you purchased and what modifications you needed to make? I'm a fan of cheap off the shelf components like this. I don't believe that I've ever helped construct a FIRST robot with a drivetrain that weighed less than 35 pounds. I would argue that reducing the weight of the upper structure of the robot is much more important. If you have a 28 pound drivetrain and 92 pounds worth of other mechanisms/components, then the drivetrain is not the part that needs to be redesigned. |
Awesome design! Question for ya, have you had any problems with plastic gears?
After comparing the "~37lbs" to other drivetrains, THAT IS VERY LIGHT FOR A SWERVE DRIVETRAIN (I think I needed those caps
). I think that that may be around how heavy the KOP chassey should be! Good work Bryce and Team 2471! |
On a side not the pocketing on then modules for the encoders was an amazing idea. The weight of the swerve is the lightest I have ever seen and will only be getting litter by the time of next season. Last edited by Tyler2517 : 14-12-2013 at 02:26. |
