Go to Post It is usually the simple things that get you. - Andy Brockway [more]
Unread 17-11-2013, 14:05
markgryzwa markgryzwa is offline
FRC #3206 (Royal-T-Wrecks)
Rookie Year: 2010
markgryzwa is on a distinguished road
Executing FRC Example lvproj files
I would like to execute the examples in the Support -> FRC Examples library.
Here's my set up. Laptop connected to CRIO. IP set to 10.te.am.0x
I open relay.lvproj. Update the IP to our te.am address.
Modify the vi for relay.vi to meet our CRIO and digital sidecar layout.
Click on the -> run arrow from the labview front panel.
See the software compile and deploy to the CRIO.
The front panel returns with what looks like run mode. Click on the controls on the front panel to change relay settings.
Nothing.
Did I miss a step? Am I wrong to think these will run without the driver's station running?
Lost, please help.
Mark G
Unread 17-11-2013, 14:11
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Rookie Year: 2012
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
Re: Executing FRC Example lvproj files
In any I/O code testing, you will need the driver station open. If it is not open, the robot defaults to disabled and outputs are stopped. There are a few corner cases where you do not need the driver station in order to test code, but those are mainly communicating with the dashboard.
In short, yes, you need the DS to be running and enabled to see changes in relays and other outputs. If it is still not working, please reply so the CD community can help.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The examples have the same limitations as the regular robot code. You need to have the driver station running and enabled to be able to control hardware (like a relay).
Unread 23-11-2013, 12:53
Rookie Year: 2010
Working exactly as you described. Thanks to CD community.
