Go to Post Robot shoots forward across field and jams itself into opposing alliance bridge. It was, however, the fastest our robot ever went. - PandaHatMan [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 23-06-2002, 23:18
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Next Question - Check Valve
Posted by Josh at 1/20/2001 12:33 PM EST
Engineer on team #419, Rambots, from Wentworth Institute of Technology.
Alright, here's another little bugger of a problem. We are trying to rig up the check valve in the p-new-matt-icks so that we can take the compressor off if it's absolutly necissary. The only problem we are having is that the manual says nothing about how it works. all it says is we have to find a way to "release preasure between the check valve and the compressor." I've tried a whole lot of things but nothing seems to work. i can get them at different preasures, but it STILL doesn't work, whenever i release the rest of the preasure, both sides of the check valve empty out. could it be that i have it in wrong? i followed the diagram, and i have it as follows:
compressor -
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
Dismantle Solenoid valve? archiver 2001 2 23-06-2002 23:34
Controling Pneumatics archiver 2001 14 23-06-2002 22:44
WDW Park Hopper Passes-How to check joe_balint General Forum 19 21-05-2002 16:28
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
