| Thread Tools |
Rating:
Display Modes |
#16
Re: Mecanum Differential Drive
While you can't run a 6 CIM mecanum, you are ignoring the fact that at this weight and complexity you might as well make an octocanum or swerve. Quote:
I'm not ignoring that, I even stated it as a problem in the OP.
#18
Actually, thinking along these lines, has any team tried a 4-shifter mecanum with locking rollers? Seems to me it might be a nice alternative to octanum; it'd offer pretty much identical functionality with comparable complexity/weight.
#19
Complexity and weight isn't comparable whatsoever. Look at 3928 butterfly and 973's offseason butterfly. Substitute in mecanums and you have a octocanum. Their drives are significantly less resources than a WCD even and almost as light.
#20
In terms of moving parts, you've got four extra cylinders on a locking mecanum system, yes, but you remove the need for an extra belt, axle, and pulleys. With the probable advent of 4'' mecanums from VexPro (which one could run straight from a CIM with direct-mounted gears and no gearbox), octanum does get quite a bit lighter, admittedly. Last edited by Oblarg : 23-11-2013 at 17:13. |
#21
What about a swerve drive with mecanum wheels? haha nevermind...
#22
With locking plates on the mecanums, of course. |
#23
Care to expand?
#25
They both use the same basic design:
https://scontent-b-lax.xx.fbcdn.net/...29116488_n.jpg https://scontent-a-lax.xx.fbcdn.net/...54889069_n.jpg Essentially they have gotten butterfly down to the bare minimum causing it to be extremely easy to make(easier than a WCD) and just a bit heavier. |
#26
Incidentally, 4464 is making a slightly-modified version (we've made some material/layout changes to accommodate our specific machining capabilities) of that second type of module (actually, we cribbed most of our design choices from RoboWranglers - they had one of their modules on display at Worlds this year) as an offseason project. |
#27
The omni wheel is 6" dia and the traction 4" dia. I don't see the problem
#29
I am quite sure that omni wheel is 4'', with a 72-tooth VexPro gear on it; vexpro does not sell gears that are that size proportional to a 6'' omni.
#30
VexPro doesn't sell a traction wheel smaller than 4" either
