| Thread Tools |
Rating:
Display Modes |
#31
Re: Mecanum Differential Drive
It is very easy to make your own small traction wheels out of delrin and plaction tread; I've seen several teams that did this. |
#33
Of course, basically all drives in FRC (except possibly swerve) are to the point where they work quickly and well 90% of the time. It's funny to think just a few years ago just driving around the field was considered something to be proud of. |
#34
If we do WCD again next year, we'll be sticking with our bearing blocks. If we also purchased COTs blocks it makes the drives pretty comparable. With our router in house the butterfly side plates are very fast to make. Last edited by AdamHeard : 23-11-2013 at 20:58. |
#35
![]() For the sake of completeness, the pulley ratio from omni to traction is 18:30. |
#36
Fair enough, I'll do the same. |
#37
We ran 12:64 (17.4 fps free speed) because we like things faster in California. The extra ground clearance is a bonus. Even with the 64T a lot of crud was sucked into the gears. |
#38
4464 currently has 12:72 for our offseason butterfly design, which is basically that but on a standard c-base frame and with delrin side-plates (the only CNC machining we have ready access to is a lasercutter at UMD). Might consider changing to 12:64 in later iterations if the ground clearance is a problem. Last edited by Oblarg : 23-11-2013 at 21:11. |
#39
And 973 was driving underweight which helps a fair amount. Also Californians are weird. -Aren |
