Go to Post Most of our old robots have been scrapped for parts. Our Chairman submissions are still read every year by the whole team. - N7UJJ [more]
  #31   Spotlight this post!
Unread 03-12-2013, 20:24
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: New AndyMark Wheels
My assumption is that the desire to switch the kop frame to direct drive was to make it harder for teams to not finish matches driving from chain failure. Making the outer axles live axle does nothing to benefit this.
So, to do this cleanly Andymark needs a new KOP wheel that's live axle and cheap. No sense in recreating the outer wheels (which are dead axle), so use the HiGrips.
As for the difference in tread, just trying stuff out I'd guess. Maybe the HiGrips will be sold with such tread as well.
  #32   Spotlight this post!
Unread 03-12-2013, 22:57
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Originally Posted by geomapguy View Post
The only problem with that theory is that they only offer them in 1/2" hex and 8mm. Could either of these work for dead axle????
Could the hex version have a recess machined into the flat side to insert a bearing? If you use this in combination with the 2013 KOP belt pulleys - they already have a bearing recess.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
  #33   Spotlight this post!
Unread 03-12-2013, 23:29
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Or, you know, the KitBot could be all live axle. Probably not... but you never know.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
  #34   Spotlight this post!
Unread 04-12-2013, 13:52
Brandon_L Brandon_L is offline
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Anyone else having issues importing the STEP to Solidworks?
The model is still usable but it has a couple errors, and I'm a perfectionist so it bothers me endlessly. Attempting to heal them didn't work, might just go back and see if I can manually fix it later.
FRC 2495 - Hamilton West Robotics [2007-2014] - whats a..."hive mind"?
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
  #35   Spotlight this post!
Unread 04-12-2013, 14:12
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Out of curiosity, I checked out the model, and it doesn't look like this would be all that easy to do. The flat face's thickness is about .15" (according to the model) and the round portion that holds the hex bore over the wheels width is ~.9" diameter - so using either an R6 or R8 bearing looks to be a bit unfeasible.
With that being said, if you really wanted to use these in a dead axle setup, you should be able to get away with taking one of the wheels with an 8mm ID Bore, and opening the bore up to 1/2" ID (round) and then pressing 1/2" OD, 3/8" ID bushings in. It's worth doing the load calculations for the specific bushing you'd use, but at a glance, it seems like it'd be okay.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
  #36   Spotlight this post!
Unread 04-12-2013, 17:07
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Seem pretty durable?
Did you get hex or 8mm??
Sorry for being slow to get back here -- kinda busy in the lab today.
I got two wheels with hex bore. Rigged up a VexPro hex test shaft on some bearings resting in v-blocks, and an indicator to measure face runout near the outer edge of the black plastic. TIR was about 0.015 inch and I think some of that was caused by sloppy internal clearances in the bearings. These wheels appear to run pretty true.
I have not made a traction test set-up yet. Materials appear very similar to those used in other AM wheels that have been included in FRC kits for last several years, so I anticipate similar CoF. Interesting that the treads are crowned, rather than flat or dished as many other AM KoP wheels have been. This has me thinking they might be useful on the corners of a 6WD or 8WD set-up, with very little mid-wheel drop required.
Richard Wallace
since 2003
