Go to Post Not even close to ready...can we delay it till like...January 2010? - Cory [more]
Unread 04-12-2013, 21:03
ming08108 ming08108 is offline
FRC #4795
ming08108 is an unknown quantity at this point
DriveTrain Ramp Up
The hardware team said that the drive motors should ramp up instead of going whatever speed the driver pushes because it draws too much current.
I have read a bit about PID loops (don't fully understand them) and something about jaguars having hardware PID if you use CAN.
I was wondering what the best way to implement this ramp up is and how fast a good ramp up rate is.
Our robot is using Jaguars for the drivetrain and Java command based programming.
Code is here:
https://bitbucket.org/ming08108/eastbots-java-code
Any help is appreciated.
