Go to Post There are few things I hate more in life than electrical tape residue. - AdamHeard [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 23-06-2002, 23:34
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Gyrochip for Straight Steering, any tips?
Posted by Elliot Johnson at 1/24/2001 5:54 PM EST
Student on team #218, HP Robotics Team, from Highland Park High School and Double-E Inc..
Our team has been thinking about using the gyrochip to keep the robot driving straight - a problem for us the past three years. I seem to remember reading about some other teams that have attempted this in the past. Does anyone have any tips or suggestions about doing this?
Thanks,
Elliot Johnson
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Feedback loop on angular rate
Posted by Joe Johnson at 1/24/2001 6:36 PM EST
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
In Reply to: Gyrochip for Straight Steering, any tips?
Posted by Elliot Johnson on 1/24/2001 5:54 PM EST:
The Gyro Chip is WONDERFUL for this purpose.
Basically you need to form a feedback loop based on angular rate.
With single joystick control use X for "desired rate of spin" and use Y for base throttle.
Calculate a "spin error" which is basically desired rate of spin minus the actual rate of spin (from the gyro of course)
Right Throttle becomes
Base Throttle + Constant * Spin Error
Left Throttle becomes
Base Throttle - Constant * Spin Error
There is a LOT of details to work out to make PBASIC do what you want it to do, but that is all you really need.
Adjust the Constant to make your robot drive like it was an Formula 1 car.
Joe J.
[IMG] code is Off
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
What is crab steering?? Adam Y. Technical Discussion 18 30-12-2002 08:12
4 wheel steering/ Crab Huey_Da_X-cat Technical Discussion 3 11-02-2002 22:49
