Go to Post but you can rest assured: I have restored the balance by letting the GDC know that I know that they know that you know they have a pattern. -Leav - Leav [more]
Unread 08-12-2013, 23:24
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Sheet Metal and Bumpers
Our team is currently working with a local sheet metal company to get ready for the 2014 season. We have been working on various designs and are wondering how teams mount bumpers.
http://www.chiefdelphi.com/media/img...9a78765c_l.jpg
http://www.chiefdelphi.com/media/img...77f7df86_l.jpg
In the above pictures, are bumpers mounted in the indented panels? How exactly could we mount bumpers?
-Graham
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 08-12-2013, 23:28
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Sheet Metal and Bumpers
Generally speaking, you could fashion a mount to attach to the top areas pretty easily. You could also bend up some mounts to go into the pockets and put bumper mount points there, similar to a WCD's bumper mounts. Or you could reverse the panels that create the indents. Or... You could get creative and come up with something completely out of the box.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 09-12-2013, 00:28
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
-Graham
Those look familiar...
The inverted outer C rails were used in 2009 to recess the live axle bearings, so they could not be exposed directly to the bumper frame. Small wood or plastic blocks were added to provide additional backing behind the bumper (you cannot mount bumpers into the indented portion of the frame unless that frame is removed with the bumpers).
At the time this was the easy way out, but after putting more thought into it in 2011 we were able to swap the C rail back to facing inwards. The bearing protrusion issue was solved by adding a 1/8" sheet metal shim to the inside of the center wheel and having the outer wheels inside a separate bracket inside the knocked off corners.
The bumpers we used on those frame styles generally had 1/2" aluminum posts mounted onto the frame, then sheet metal brackets added to the bumpers. They would be added and taken off vertically, with hairpin cotter pins (R-clips) used to keep them in place. The 2011 frame had segmented bumpers that were added and removed horizontally, although I believe in 2012 and 2013 they returned to bumpers that were added and removed vertically (over the top of the robot).
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 09-12-2013, 00:54
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
Thanks for the direct relation (I presume you were the CADer )
So take the 2009 frame for instance, if we did something similar with the c rail facing outwards, but created a bracket that connected the top and bottom rails and then latched to the bumpers.
Something like this? (ignore the pitifulness of the AutoCAD mockup haha)
https://drive.google.com/file/d/0B2O...it?usp=sharing
Unread 09-12-2013, 02:02
artdutra04's Avatar
After looking back through photos, here's a photo of the blocks used to fill this void on the 2007 robot. http://team228.org/media/pictures/view/3000
Art Dutra IV
世上无难事,只怕有心人.
Unread 10-10-2014, 14:56
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
I just came across these when researching the same problem on our prototype. Seems like the perfect solution:
http://www.mcmaster.com/#94850a129/=u3dumi
On second read, I should be a bit more clear - if secure the bumpers to the top flange of the outer rails (using the panel nuts), rather than inwards to the webs, you should need any spacers (you might need to make the bumpers one or two pieces though, and have them wrap around the front and back rails.
Unread 10-10-2014, 15:55
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
We used those (or something very similar) last year and they were terrific. It made for probably the fastest bumper change we've had.
Unread 10-10-2014, 19:45
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
We used twist latches this year and so did 1477. They aren't perfect but they are very quick to change. If we use them again next year we will use more than 4 and probably use the larger ones like 1477 did. We had them come off a few times.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 10-10-2014, 20:07
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
If you don't mind your bumpers coming off a little more slowly, you can effectively use them as a structural member.
In 2013 33 ran a single piece bumper system with the mounting hardware being a 2x1 welded box beam going all the way around the robot mounting to the underside of an outward facing flange.
This is what it looked like.
Just another option to consider.
Cheers, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 10-10-2014, 20:11
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Last year my team used something similar to this. We attached a right angle bracket to our bumpers, and then use the the slide latch to attach the bracket to the top flange of our frame.
