Go to Post No way thats Dean... he didn't give an hour long speech :p - AndyB [more]
Unread 09-12-2013, 12:15
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Omni vs Mecanum CoF ?
I am looking at the differences between Omni-wheel drive (Killough) and Mecanum drive. I think I understand the cos(45) difference in forward torque and corresponding difference in velocity. I propose that rotating the Omni-wheel could be modeled as a wheel with radius of 1/cos(45) and if this larger wheel Omni-wheel was geared for the same maximum velocity, the available torque would be the same as the original mecanum wheel.
The discussions to date have suggested that there is a relative loss of available traction for the omni-wheel system since the torque of the wheel to the carpet is sqrt(2)/2 larger and will brake traction sooner than the mecanum wheel. Looking at the AndyMark specs for their wheels the Coefficient of Friction for the 6" Omni-wheel is 1.0 where as the CoF for the 6" mecanum is 0.7 F&R - the same sqrt(2)/2 ratio!!! For strafe, the mecanum CoF is only 0.6 which is additional sqrt(2)/2 loss (which I believe is expected).
From a practical standpoint, it would appear that there is no traction advantage for macanum over Omni-wheel drive with the wheels available to FRC. Assuming AndyMark uses the same rubber for both wheels, does this suggest that mecanum drive has the same theoretical loss of traction as Omni-wheel drive? Can anyone explain or dispute these observations? I know that swerve does not suffer from these losses, so lets keep the dialog limited to Omni-drive vs. mecanum drive.
