Go to Post Flattery will get you everywhere. - nuggetsyl [more]
Unread 09-12-2013, 17:10
samn122 samn122 is offline
FRC #0334
samn122 has a spectacular aura aboutsamn122 has a spectacular aura about
Gyroscope Not Returning Degrees
We're programming a gyroscope on the robot and we're not getting a readout in degrees. The sensitivity is set to 0.007 (as referenced in the manual), the gyro is connected correctly and mounted on the robot. The readout we get is also not consistent because it decreases while stationary and we don't think it's drift. We tested sample code and read the manual but we're still having a problem.
