Go to Post I don't care what the team numbers said, on Friday there were no rookies there. - Taylor [more]
Unread 10-12-2013, 15:22
cramir cramir is offline
FTC #5911
cramir is an unknown quantity at this point
[FTC]: HELP motor not working during teleop (labview)
hi i am a begineer programer and my problem is that one of the motor just doesnt work at all in the teleop code. i created the code using the labview controler configuration. i generated the code but i notice when i looked at the code( always double check codes) that that particular motor wastn there but intead the constant was of a lego motor. i changed the constant to the correct motor and deploy it, everything else work but that i have other 3 motor and 2 servos working perfectly. i already tried everything please help!!
Unread 11-12-2013, 09:23
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Rookie Year: 2012
Robo Hamsters is an unknown quantity at this point
Re: [FTC]: HELP motor not working during teleop (labview)
If you want to send the code to us (Robo Hamsters FTC 7042/FRC 4466) we would be more than happy to take a look at it and see if we can help.
Send it to admin @ angelictech . com
FRC 4466
FTC 7042
2013 Washington DC Regional Finalist
Unread 13-12-2013, 01:43
RoboFalcon3 RoboFalcon3 is offline
FLL #1958
RoboFalcon3 is an unknown quantity at this point
Not sure if this is related, but i found this on the NI website:
FCS is running circles during the Teleop time
FTC 7998
