Go to Post I said it was called FIRST Robotics and the coolest thing I'd seen that day was a 150lb robot balance with another one on a teeter-tooter and and then score basketballs from 30 feet away. - Siri [more]
Unread 10-12-2013, 19:59
nrogals nrogals is offline
None #3173
nrogals is on a distinguished road
CIM Motors reusable?
So we have about 11 older CIM motors. My team wants to know if it would be better to use our older motors for the time being until we get new motors later in the season, or if we should get the motors immediately. Is it really that bad to use older motors for a little bit? Would anything terrifyingly horrible happen to our prototypes? I believe that they are 2011 and 2012 motors.
Unread 10-12-2013, 20:01
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Re: CIM Motors reusable?
I think you may have a tad lower performance, but CIMs and MiniCIMs shouldn't have the wear that evident. Just avoid reusing BAG motors. They don't have a very long lifespan because the bearings get destroyed by the high RPM, (14,000RPM). Those are the main motors that I have played with in the one year I have been of FIRST!
Unread 10-12-2013, 20:05
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
You might see a slight performance gain in newer CIMs, and the older ones may be slightly prone to failure, but you'll be fine. Our team routinely uses CIMs from at least 6 years ago and older.
Unread 10-12-2013, 20:06
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
If they're the same part number, go for it. I haven't seen any apparent drop off in performance from a CIM in storage.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 10-12-2013, 21:29
Patrick Flynn Patrick Flynn is offline
Rookie Year: 2010
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
Can anyone provide some evidence to this? I have never heard a report about BAG motor bearings failing. And would be interested to see what situations caused these issues?
Unread 10-12-2013, 21:40
AKA: null
Rookie Year: 2012
Our shooter BAGs kept failing. We took a couple apart and the bearings were shattered, and looked partially burnt!
Unread 10-12-2013, 21:48
Nathan Streeter's Avatar
Nathan Streeter Nathan Streeter is offline
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Nathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond repute
... how'd you mount them? Did you direct-drive them and not support the shaft? If this is the case, I can't claim I'm surprised...
"If you want to build a ship, don't drum up men to gather wood, divide the work, or give orders. Instead, teach them to yearn for the vast and endless sea." - Antoine de Saint-Exupery
"The fight is won or lost far away from witnesses - behind the lines, in the gym, and out there on the road, long before I dance under those lights." - Muhammad Ali
"Simplicity is the ultimate sophistication." - Leonardo da Vinci
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 10-12-2013, 22:13
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
The likely cause of the bearing failure was explained to him in an earlier thread but he seems to have ignored it:
BAG motors have such a high RPM that they self-destruct their internal bearings.
Originally Posted by stinglikeabee View Post
I doubt speed was the root cause of the BAG motor failure. Improper side-loading on the bearing due to a shaft-mounted shooter wheel or an overtensioned belt was likely a root cause if the bearing itself failed.
Unread 10-12-2013, 22:16
AKA: null
Rookie Year: 2012
No. I did read that post. I just haven't replied to it yet. We have a versa-planetary gearbox. I believe that those are built for motors like the BAG motors. It could be side-loading, but that wouldn't cause motor problems because doesn't the typical gearbox separate the motor from the drive-wheel?
Unread 10-12-2013, 22:20
Ether's Avatar
Rookie Year: 1969
Seriously? That was 2 and a half weeks ago... during which time you have made 200 posts.
As a general rule, if you haven't made the effort to discuss failures with the supplier to understand why the failures occurred -- especially in the case of products from major FRC supporters such as VEX -- please don't use this forum to bad-mouth their products.
Unread 10-12-2013, 22:24
AKA: null
Rookie Year: 2012
Yeah. That is a good idea. I am not trying to bad-mouth them. As a matter-of-fact, I really think the CIMs are one of the best drivetrain motors!
Unread 10-12-2013, 22:39
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Cool. That means you are the 99%.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 10-12-2013, 22:45
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
http://www.chiefdelphi.com/media/photos/19904
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 11-12-2013, 09:57
jeremy callahan's Avatar
jeremy callahan jeremy callahan is offline
Mentor
FRC #5053
Rookie Year: 2011
jeremy callahan will become famous soon enough
we also had some issues with the bag motor. they ran great at the beginning but at the end of the day you would have to resort to "kick starting" the wheel to get it up to speed. If we could figure out how to stop having to "kick start" it we would like to use them. But we just don't want to have to rely on that in the middle of competition. That's our opinion on them.
  #15   Spotlight this post!
Unread 11-12-2013, 10:21
Ether's Avatar
Rookie Year: 1969
The information you provided would be much more helpful with further context. Please post details of your shooter design,including:
- how the motor was mounted to the frame and to the wheel
- disk compression
- gear reduction from motor to wheel
- speed of the motor at shooter operating speed
- wheel speed controller (e.g open or closed loop)
- duty cycle (continuous or on-demand)
- pictures would be helpful
- if you have it, motor amps at operating speed
But more importantly: Did you contact VEX, and discuss this with them, and send them the motor for failure analysis?
