Go to Post I don't remember ever having "attack of the jumbo ball" in FRC! - Beth Sweet [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 11-12-2013, 19:35
khanh111 khanh111 is offline
Outreach/Scouting/Software Manager
AKA: Hamzah Khan
FRC #1540 (The Flaming Chickens)
Team Role: Student
khanh111 has a spectacular aura aboutkhanh111 has a spectacular aura about
Internet at Competitions
My team has traditionally used a web application for our scouting application which has allowed our scouting head in the pits to access data from the stands.
However, we have enormous problems with internet access each year that we attempt to negate through use of various offline technologies.
We use 6 tablets, each with 4G internet access from AT&T in Portland (and Champs). However, at Portland, and especially Champs, the internet access will not work due to network congestion.
For other teams who use web apps, how do you access the internet?
Thanks!
Unread 11-12-2013, 19:53
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
Re: Internet at Competitions
We use a similar setup (4G tablets), but we've also got a 4G modem that has a bit better antenna if we really need it that we can wire into our tablets. Our scouting software has the ability to temporarily cache the data if it can't upload it to the database. It holds the data until a connection is established, then dumps it all at once.
Unread 11-12-2013, 20:05
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
I think that it would be wise to carry something like a 1W 4G antenna (if you can even get one). You'll be able to communicate with a tower possibly 80 to 100 miles away! Connect that into a switch and that can offer ethernet connectivity. That's where Windows tablets come in use! They have ethernet ports!
Otherwise, since you are running a webpage-based scouting app, just run the server at the competition! That is the reason why the scouting app I'm working on will be a fail. Even though I am heavily using WebCache to store the page, an internet connection will be required. Since you live in the West coast, like me, you might want to use Verizon or Sprint or ATnT. WiMax will give a 40 mile range! Even better, have a WiFi pack running a 16 Watt antenna (you'd have to build this yourself!) with you, and one copying your hotel's wifi! You'll get WiFi from anywhere in the city!
Unread 11-12-2013, 20:38
arbym arbym is offline
AKA: Rob Miller
arbym is on a distinguished road
We actually queue the transactions which is different than caching the web page. We estimated last year that we could run several hours without a 4g signal. At worse case we could walk out to a hallway or even outside to flush the queue.
Rob Miller
Scouting Mentor
Innovators Robotics
Unread 11-12-2013, 20:46
AKA: null
Rookie Year: 2012
I think that it is time that FRC makes available a limited-use wireless network, only available to certain people! That would make internet access possible without causing too many robot network communication troubles!
Otherwise, why doesn't FRC special-order the radios to work on a special frequency? Maybe even a channel not used very often.
I have two routers at home, sitting next to each other. They used to fight over the signals, causing them to get very hot and keep on crashing. I changed the channel of one of the routers and now I get no problems!
Unread 11-12-2013, 21:19
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
And everything old is new again: http://team358.org/files/electrical/...Manual2007.pdf
FIRST moved away from custom radios to make it easier to utilize COTS parts/systems during competitions. Things might swing the other way soon enough.
Unread 11-12-2013, 21:21
DonRotolo's Avatar
Back to humble
FRC #0832
Why in the world would you need Internet access for scouting? What is it you need from outside the venue?
Unread 11-12-2013, 21:27
AKA: null
Rookie Year: 2012
I mean a small difference, just in the antenna, like 2.6GHz instead of 2.4!
I want to design a scouting application that will allow every team to view the same results and use the same tools. The server will be at home to make sure everyone around the world can connect to it!
Unread 11-12-2013, 22:02
Brandon Ha Brandon Ha is offline
FRC #0302 (Dragons)
Team Role: Electrical
Rookie Year: 2011
Brandon Ha is on a distinguished road
I am speaking from FiM's side, which is WiFi is bad. Do NOT use it at competitions. Many things can and will go wrong, not for the users but the field people. They will get angry at you.
We all make mistakes.
I make one everyday.
The important thing is.
( \_/ )
(^_^)
Unread 11-12-2013, 22:35
AKA: null
Rookie Year: 2012
First of all, do you mean FMS (Field Management System)? Also, you say, don't use WiFi in the competitions, but you don't really explain why. Also, yes, they will get angry at you, but it isn't a bad thing, like how you are making it sound. That is to just keep the fields working properly. WiFi is a thing that is quite useful in competitions because it will network devices together, allowing them to communicate. That is the reason why you use Bluetooth in competitions!
Bluetooth should be good as long as you aren't torenting a 16GB file (you'll get angry by the 3MBps max speed)!
Unread 11-12-2013, 22:37
Abhishek R Abhishek R is offline
FRC #0624
Rookie Year: 2012
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
FiM = FIRST in Michigan. Though I'm not sure which one he meant, now that you bring it up, but I'm fairly certain he meant FiM being from a Michigan team.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 12-12-2013, 00:19
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Interference. That's why no WiFi. Field working properly is HUGE! You weren't around in 2012, I don't think--get your hands on a copy of the Einstein Report from that year, and see just what can go wrong if either the field or the robots aren't working properly.
FYI, all: From the 2014 Administrative Manual, Section 4.15, 3rd bullet:
Do not arrange for Internet access or phone lines on the site or attempt to connect to the Internet.
I'm guessing this replaces the WiFi restriction from 2013 and prior years.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 13-12-2013, 02:17
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Rookie Year: 2011
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
So if I am understanding this correctly, we cant use the Internet at all during competition anymore? Even over 3G/4G?
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 13-12-2013, 23:52
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
Rookie Year: 2011
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Actually, I think they are trying to keep people from getting temporary land lines or internet lines run for them for the event because at many venues these services are available to the events they host at additional significant cost. They are also trying to discourage people from jumping onto local existing wireless networks and swamping them away from people who have a legitimate use for them (such as the router owners).
The WiFi restriction will most likely be in the competition manual again.
EDIT: Yes, what Ankit S said two minutes ago ...
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
  #15   Spotlight this post!
Unread 12-12-2013, 08:47
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Here's why - FIRST has asked teams nicely NOT to use wifi at events as it interferes with the Field. Yes, ticking off the FTA is a bad thing. They are already stressed enough without your punk team deciding the rules don't apply to them for WHATEVER reason you are using to justify it.
Frankly, I'm appalled that you're so easily discussing interfering with the field. But I'm more annoyed at how easily you discount the impact your actions will have on the volunteers who will face the repercussions. Because when the field doesn't work nobody is going to come to you, they'll go to the FTA and then the FTA will have to spend an hour of their time hunting down your stupid wifi network while listening to people blame them/NI/Cisco.
[IMG] code is Off
