Go to Post If poker is a sport, robotics is definitely a sport. - EricH [more]
  #31   Spotlight this post!
Unread 14-12-2013, 11:09
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: MicroControllers at competitions
Originally Posted by yash101 View Post
.025 ohms was just a practical example
It's not practical. .025 ohms will have a significant effect on motor torque.
In real time, I would use a 25mOhm resistor
25mOhm is .025 ohms.
Also, about the inductance-based current sensors, don't you need a circuit to constantly monitor it if you are using DC?
A clamp-on DC ammeter uses a Hall Effect device to sense the static magnetic field created by the DC current.
  #32   Spotlight this post!
Unread 14-12-2013, 11:16
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Sorry. I confused mOhms with uOhms!
I think it would be better to skip the resistor and bring along a foot of gauge 8 wire. That aught to do it without over-dropping the voltage.
Using a hall-effect sensor is a different way of thinking about it! I was thinking about measuring current by creating a transformer, with the second winding as a coil around the main wire!
  #33   Spotlight this post!
Unread 14-12-2013, 14:42
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
If you are truly looking at shunt resistors <<25mohm you absolutely should use the voltage across the wire from the PDB to the speed controller. The resistance of the wire per foot is easily found online and will be just as accurate as a resistor you could afford to add - plus its FREE. Just put a volt meter across the wire (or add your micro-controller). If you are looking for a failure, the difference between 133 amps and 125 amps is not really relevant anyway.
  #34   Spotlight this post!
Unread 14-12-2013, 15:03
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Assume you use a 25µΩ resistor. At 100 amps, how much voltage drop would there be? How many useable bits of resolution would there be between 0 amps and 100 amps with your ADC?
  #35   Spotlight this post!
Unread 14-12-2013, 16:54
AKA: null
Rookie Year: 2012
To increase the 12 bit resolution, I want to decrease the vRef voltage to something like 1v or .1 v, etc.
  #36   Spotlight this post!
Unread 15-12-2013, 13:00
FRC #1559
As someone who designs ADCs for a living, I strongly recommend against using a Vref less than 1v. At 1volt each count of yor ADC is already 25uv and noise of a CMOS amplifier is about 10uV. The best answer is to use a resistor that gives you a voltage that matches the input range of your ADC. I still think the suppy wire is in the right range. The key is to use a high impedance sense circuit with a Kelvin connection in parallel with the supply routing to the speed controller so a not to influence the system performance.
  #37   Spotlight this post!
Unread 15-12-2013, 15:05
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Dev,
Your original statement about DC is true for transformers. You only get an output when the input (primary) is a varying voltage. In a transformer, when you switch on a DC current, the secondary will produce an output during the transition and then settle back to zero. That is why Hall effect devices are used for current monitoring in DC applications.
Al
WB9UVJ
www.wildstang.org
________________________
  #38   Spotlight this post!
Unread 15-12-2013, 16:27
AKA: null
Rookie Year: 2012
That makes sense. Does anyone have a good place for me to grasp info on how hall-effect sensors work? I am interested in these neat devices!
  #39   Spotlight this post!
Unread 15-12-2013, 16:40
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
2 for one - tutorials and something specific for hall effect sensors.
http://www.electronics-tutorials.ws/...ll-effect.html
So has anyone used a length of wire, resistor or hall effect sensor on a fielded robot as a current sensor?
  #40   Spotlight this post!
Unread 15-12-2013, 21:27
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
At IRI a few years ago, I know a few robots had self-contained logging hall-effect current sensors strapped against the battery leads. I don't remember finding out who was responsible for them.
  #41   Spotlight this post!
Unread 15-12-2013, 21:45
Rookie Year: 1997
FIRST was trying to determine current draw in order to set the requirements for the 2009 PDB.
  #42   Spotlight this post!
Unread 16-12-2013, 07:40
Unsung FIRST Hero
Rookie Year: 1996
WildStang manufactured a current monitor called StangSense a number of years ago. We used a one foot piece of #10 wire and a current monitor circuit from Maxim. We then ported the data to the robot data link and recorded the data at the driver's station. I believe the file is still on CD someplace.
The current monitor that was added to robots at IRI was from HQ. They wanted to gather data to confirm the high current spikes I had mentioned in conversation. The data recorders were supervised by Wayne Penn as I remember.
Al
WB9UVJ
www.wildstang.org
  #43   Spotlight this post!
Unread 28-12-2013, 12:37
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
http://www.andymark.com/product-p/am-2709.htm
New product from AndyMark, using a Hall-Effect, but needs to be inserted in the circuit.
