Go to Post Too many hours of robotics and too little sleep causes me to forget things.... - AdamHeard [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 13-12-2013, 13:44
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
Team 610 pre-season drivetrain
Two of our grade 11 students took it upon themselves to design and build a drivetrain during the pre-season. Matt and Jonathan did a spectacular job, putting in a lot of time working out all the details in CAD, and then machining all of the parts themselves.
I encouraged them to try some new things, since that's what the pre-season is for. Here are the specs:
-Fully geared
-8wd, front wheel raised 3/16"
-6" aluminum performance wheels
-Single speed: 10fps (it's all about acceleration)
-Riveted frame construction
-Fiberglass belly pan
-Beefy, heavy construction (didn't care about weight on this one)
It should be driving soon!
Unread 13-12-2013, 13:53
Re: Team 610 pre-season drivetrain
Pretty sweet, I like how much space you save with the thin tubing.
Did you have issues with assembly? Any access holes at the bottom to help assemble the geared drive?
Unread 13-12-2013, 13:57
rsisk's Avatar
rsisk rsisk is online now
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
What gauge is the wire going from the DSC to the controllers?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 13-12-2013, 14:14
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Very nice! It's laid out much better than most of the stuff I have to work on. It looks better thought out too.
How did they install the gears in the tubes down each side?
If I only had hiring and firing authority...
Unread 13-12-2013, 15:35
FRC #0610 (Coyotes)
The tubing is 1 x 4, the gears just roll in from the end. Assembly was surprisingly easy.
Unread 13-12-2013, 16:14
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Rookie Year: 2012
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Looks very well designed and made! Mind posting a video when it's driving around?
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 13-12-2013, 16:52
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
Very nice!
One speed 3 cim definitely has it's advantages, less parts weight and complexity. easier to predict when driving(less thinking about shifting/waiting for auto shift). At 10fps I can't see you guys popping a breaker unless you were REALLY trying, maybe a push fight against a 2cim shifter going at 6fps. I remember you guys browning out a few times last year at 9fps, is there any way you are looking to avoid these brownouts in the future?
This project probably started before vex did their unveiling. Now that the 3 cim ball shifter is available would you consider it as a replacement for your beloved single speed?
Unread 13-12-2013, 17:45
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
6 Cim's and a battery at the back. May want to distribute weight better. Always beware of Center of Mass.
Unread 16-12-2013, 01:58
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
We typically run only 12 Gauge wire to our motors. We try and standardize on two gauges: 12 and 18. Very generally (there are always special cases) motors will get 12 gauge, and everything else that requires a circuit run from the PDB will get 18 gauge. It's pretty simple for our students to follow, and for them to explain during inspections.
This is the first time we've used Talons, and are very curious about their linearity, and how they'll behave with our software PID control.
Once it's driving we'll likely post a video, but I doubt it'll be much more interesting than any other FRC drivetrain doing laps.
The brownouts from our 2013 robot were traced back to a faulty 12v->5v DC-DC converter for the radios. We didn't catch this until we were on Einstein when the field support crew informed us that our radio (not cRIO as we originally thought) was losing power. We replaced it at some point on Einstein as we were placing the robot on the field for a match - I don't remember during which match. After that, the brownouts ceased.
Our drivetrain choices are driven by game strategy requirements. I wouldn't rule out a multi-speed gearbox in the future, but there would need to be very good reasons. We optimized last year for multiple 36ft start-stop sprint between the feeder station and pyramid, and for getting around defenders. Optimizing for, say, Overdrive in 2008 was a different matter completely. I don't think our team has ruled out anything, but we always try and find the simplest and most reliable solution to achieve the objectives that our Strategy team sets. Being able to build something that's maintenance free is also a big deal.
If the drivetrain strategic objectives were the same as last year, I think it's safe to say we'd stick with the single speed. In fact, we might've gone down to 4 CIMs, as the 6 CIM decision was somewhat a product of our power-takeoff climbing time requirements.
The weight distribution is definitely biased for just a drivetrain, however I don't lose any sleep over it. We developed this drivetrain with the intent that we hope to actually use a similar design on a full FRC robot someday. There's room if we need an open front for an intake, and the top-half of a robot is usually weight biased as well. We actually didn't know which end of our drivetrain would be the front of our robot until close to week 3 last year - and this gave our programmers fits! We intend on testing this drivetrain at full competition weight at some point, so ballast will be going on, and the weight distribution will be adjusted at that point.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 16-12-2013, 02:30
ErvinI ErvinI is offline
AKA: Ervin Ibadula
FRC #0865 (Warp7)
Rookie Year: 2011
ErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really nice
Some dubstep will make the video more awesome.
What are you expecting that is different with Talons regarding PID control? I believe that you guys mentioned that you were using CAN last year. I'm not too familiar with it, but if I recall correctly it does some of the framing for you regarding PID control. I guess that part will be different.
However, we used PID control last year for our drivetrain running 4 Talons. Proved to be accurate within 3 inches over a 100 inch drive if the count-to-inch conversion was accurate, and that was with little tuning on the drivetrain ("Test mode" only works for one motor at a time, and we relied upon it for rapid tuning). For FRC purposes, I can't imagine that non-linearity is that significant between, for example, a Talon or a Jaguar running CAN.
Currently a student at the University of Toronto - Mechanical Engineering
FRC 781 alumni
Unread 16-12-2013, 09:11
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by ErvinI View Post
I can't imagine that non-linearity is that significant between, for example, a Talon or a Jaguar...
If it helps, there is actual test data available here:
http://www.chiefdelphi.com/media/papers/2720
Unread 16-12-2013, 15:11
FRC #0610 (Coyotes)
I doubt it. In my opinion, two speed transmissions are silly and largely unnecessary. In most robot games, the vast majority of your movements will be short sprints from game piece to goal, and avoiding other robots in between. This calls for acceleration, not a high top speed. Slower is faster.
Unread 16-12-2013, 19:24
Kernaghan's Avatar
Kernaghan Kernaghan is offline
Technical and Driver
FRC #4814 (United Robotics team of London)
Rookie Year: 2012
Kernaghan is on a distinguished road
This is really cool. I've been CADing some very similar designs (putting gears inside the rectangle tubing), so I have a few questions. What type of gears are you using, aluminum, steel, what manufacturer? Also gears do not absorb force like belts and chains do, how are you planning on mounting the bumpers so the forces from collisions are dispersed correctly? The drivebase looks awesome, I can't wait to see what 610 comes out with this season.
______Team 4814______
"Linking London Together"
_________URL_________
Unread 16-12-2013, 19:56
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
Trapped under a pile of MECANUMS :P
AKA: @doctorfogarty
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
Where do you buy your 1x4 tubing?
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
  #15   Spotlight this post!
Unread 16-12-2013, 20:09
Kernaghan's Avatar
Rookie Year: 2012
You can get it here, stock number is T34118
