| Thread Tools |
Rating:
Display Modes |
Solenoid 12V Regulator on 24V Breakout?
We purchased 12V solenoids to use on the robot this year, and plan to get more solenoids/valves from FIRST Choice, however we noticed FC only offers the 24V variety.
I realize you can use 2 solenoid modules on the cRio to get a 24V flavor and 12V flavor, but is it permissible to installed the 12V solenoid onto a single 24V module through a 12V voltage regulator (as a custom circuit)? |
Re: Solenoid 12V Regulator on 24V Breakout?
This could work:
24V solenoids through solenoid module 12V solenoids through spikes |
I realize that works as well, but when dealing with double solenoids you end up using a lot of relays, which adds weight and cost. Step-down voltage regulators in series would be cheaper and lighter, just trying to determine if it's legal.
I obviously wouldn't recommend it and remember one Spike can control two 12v solenoids.
From my quick check of the 2013 manual, you may have an issue with this rule. Quote:
To control the double solenoid with a Spike relay, don't you just hook both positive leads from the solenoid to the 2 output terminals on the Spike and tie the ground back into the PDB? I've heard of it being done, but have never tried myself.
They take in either 12 or 24vdc to drive a festo solenoid valve. Someone correct me if i'm wrong, if you purchased the 24v soelnoids from first choice, these would allow you to run them from either 12v or 24v supply.
Note that you will need to purchase two per double solenoid valve. |
I don't think this part works this way, but the documentation I've come across isn't 100% clear on this point. My reading of things is this particular part can work with either 12 or 24V valves, but only when the applied voltage matches the specifications of the valve. There are both 12 and 24V valves in the same family that can be used with this part. In other words, this part is more like a connector and does not regulate the voltage or anything like this. I think you're stuck using valves that take the same voltage, using two pneumatics modules in your cRIO, or using a Spike for 12V and a pneumatics module for 24V. Not only would putting a voltage regulator in-line violate the rules (from past years), but this would also likely not work, at least not very well. Maybe a resistor could be used, but this would likely run into the same issues, at least with the rules.
Bottom line: I would check very carefully before trying this, particularly given the costs involved if testing destroyed a valve or one were to go bad at an event. |
#10
