Go to Post If it's good enough for Star Trek, it's good enough for FRC. :) - KarenH [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 14-12-2013, 10:34
Noam787 Noam787 is offline
FRC #4590 (GreenBlitz)
Rookie Year: 2013
Noam787 is an unknown quantity at this point
vision with simpleCV problem
So this year we are trying onboard vision using raspberryPI. For the image processing we are trying to use simpleCV lib but we got stuck when we tried to connect to the camera’s (Axis M1011) mjpeg stream with the code below:
Code:
import SimpleCV
cam = SimpleCV.JpegStreamCamera('http://10.45.90.11/axis-cgi/mjpg/video.cgi?resolution=320x240')
pic = cam.getImage()
This code is rising an error in the line “pic = cam.getImage()” :
Code:
File "<pyshell#5>", line 1, in <module>
    pic =cam.getImage()
  File "C:\Python27\lib\site-packages\SimpleCV\Camera.py", line 904, in getImage
    return Image(pil.open(StringIO(self.camthread.currentframe)), self)
  File "C:\Python27\lib\site-packages\PIL\Image.py", line 1980, in open
    raise IOError("cannot identify image file")
IOError: cannot identify image file
If anyone can help us it will help us a lot,
GreenBlitz 4590
Unread 14-12-2013, 14:22
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Re: vision with simpleCV problem
From what I've seen of SimpleCV, it's not really that much simpler than the normal OpenCV python bindings.
Anyways, try the following URL instead: http://x.x.x.x/mjpg/video.mjpg
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 14-12-2013, 14:47
Rookie Year: 2013
we tried this url too. I think the error occurs because of the stream format that the Axis camera is sending is Mjpeg and the camera object reads Jpeg stream. but, i'm not sure those are two different formats.
Unread 15-12-2013, 01:20
virtuald's Avatar
RobotPy Guy
It's very strange to me that it's using PIL to open the images received from the camera... perhaps there's a different class you can use to receive images?
If you're using the OpenCV api, getting images from the camera is straightfoward. You can get images using that URL and the following code (note that error checking is not complete):
Code:
import cv2
import sys
vc = cv2.VideoCapture()
if not vc.open('http://%s/mjpg/video.mjpg' % sys.argv[1]):
    exit(1)
while True:
    retval, img = vc.read()
    if not retval:
        break
    # do something with img...
Perhaps you could capture the images that way, and then create a SimpleCV image object from the numpy array found in img?
Unread 18-12-2013, 15:22
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
We used openCV running on a beaglebone last year with the Axis M1011. Didn't end up on the robot, but one of our students got everything working pretty well.
I'm not sure if it will help with your case as I'm not familiar with simpleCV, but we also had trouble with the mjpeg stream and ended up using the jpeg url for the camera:
Code:
http://x.x.x.x/jpg/image.jpg
http://team2168.org
Unread 18-12-2013, 17:15
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
Rookie Year: 2012
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
As per the SimpleCV wiki here, it looks like these are the list of known IP addresses and paths to the video stream. Make sure you are sending your camera's username and password via the form
Code:
http://username:pass@xxx.xxx.xxx.xxx/path/to/stream
  • Code:
    http://x.x.x.x/axis-cgi/mjpg/video.cgi
  • Code:
    http://x.x.x.x/axis-cgi/mjpg/video.cgi?camera=&resolution=352x240
  • Code:
    http://x.x.x.x/axis-cgi/mjpg/video.cgi?camera=&resolution=640x480
  • Code:
    http://x.x.x.x/axis-cgi/mjpg/video.cgi?compression=60&camera=1&des_fps=1
  • Code:
  • Code:
    http://x.x.x.x/axis-cgi/mjpg/video.cgi?camera=1&resolution=352x288
Alternatively, you could find the URL that gives you the last picture taken and use that to make an image for processing, like the previous post suggests.
Also, you may want to contact Katherine Scott (from SimpleCV, @kscottz) directly; she's involved with an FRC team and did some debugging with the Axis Camera before.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
