pic: 18 Tooth #25 Sprockets Inside VersaChassis
Re: pic: 18 Tooth #25 Sprockets Inside VersaChassis
SolidWorks tells me it'd be around .055" clearance vertically without chain installed. I don't know off the top of my head how much the chain would extend past the teeth. Either way, it's a cozy fit, but it "works" in CAD (granted, that's not a guarantee of success). I'll have the opportunity to test it using real parts sometime in the future, so i'll post results when I get the opportunity to mock it up.
The 16T sprockets are plenty big for 4" wheels and give you a tad more clearance.
Really, now... I wasn't sure if 16T would be big enough.
Nice looking model.
We have been putting 16T #25 chain inside 2 x 1.5 tube for a couple of years. If you want to do a drop center 16T is as small as you can really go. Your chain will start to stretch and loosen up, rub a bit against the wall of the tube. Assembly of 18T will be almost impossible and if you are just running a 1:1 ratio between wheels why go with an 18T? I really believe Versa is going to really change things for teams with limited fabrication abilities. Last edited by rees2001 : 16-12-2013 at 08:22. |
Two strands of #25 fit side-by-side inside a standard "1x2"x.125" wall tube.
We use 17 tooth double sprockets inside of our SimpleTube Chassis. You cannot have any drop in this setup because of clearance around the chain. Otherwise the system is great and is a nice volume save. FRC118 used this same setup for 2013 with zero failures and maintenance issues. ![]() |
#10
They had different diameter wheels. Pretty cool stuff!
